Wish mine would do that good, according to the onboard computer.
Actually filled hi p in Durango, CO. drove 550S to 160. 160W to 25S and down to Raton NM.. Mountain passes and all. Filled up in Raton with only a half a tank used.
That's just mean, cruel & unusual punishment.
WAIT, you have yours set to last 25mi.  Mine is running at "Last 400mi," and since I bought it.
I move through them all.. my 400 average is 22 mpg. The wife putts in town all week.. 12 mpg. I'm thinking she drives a little more aggressively than she let's on. [emoji16]
2 minutes ago, DHeinze said:
I move through them all.. my 400 average is 22 mpg. The wife putts in town all week.. 12 mpg. I'm thinking she drives a little more aggressively than she let's on. emoji16.png
That's why I'm the only one that drives mine.  My wife drives her CR-V in the mid-20s, and after I drive it for a day, it's in the 30s.  My daughter does okay with her MPGs in her Cruze ECO, low-30s, but when I drive it, it's in the low-40s, and she can't seem to figure it out.  :cool:
I am upgrading gearing next month. 3.23 to 3.73 gearing. Can't wait to put tires on it monthly...??
  • Haha 1
2017 1500 z71, 3.5 RC knuckle lift, TOYO RT 285/65/20, aftermarket towing mirrors, custom cab clearance lights.
Got anymore pics? How do you like the lift?
On ‎11‎/‎27‎/‎2018 at 12:39 PM, khaledsamy36 said:
Thanks !
2017 SLT - dark slate metallic , painted the bumpers same car color , changed to Denali grille - 4 inch ready lift - fuel nutz 17 wheels - bf 315 tires - borla atak dual with dual straight black tips - hd mirrors and ( Texas edition emblems )
Did you paint over chrome bumpers?
Here is my 2017 De-badged - 6" lift - K&N CAI - Catch Can - Flow Master Exhaust - Tuned - 4.56 gears
17 z71
Does the bull guard Interfere with the front bumper sensors?
Oh, BTW very nice looking Silverado!
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
