On 5/25/2017 at 1:45 AM, 6TEEN5.3 said:
My 17. Getting rid of all chrome and debadging in a couple of weeks
154fdae22c468094f309269046f50046.jpghttps://uploads.tapatalk-cdn.com/
What size tires are those and what type of lift do you have?  Also, how did you go about getting rid of the chrome?  I have the same truck but an 18 and you are setting yours up just how I want mine to look.  Looks great man.
Nice! Same question as kingofcrate, what lift and tires do u got? I have 3in front 2in rear level/lift was wanting 35x12.5 but only few people say i can run them the majority says 33x12.5,
If you zoom in on the tire where it shows the back driver side, it looks like it says 33x12.5r17
careful with those types of lights.. just a huge water leak(s) just waiting to happen..
You have a 1500, attached clearance lights...[emoji848]....aren’t clearance lights only found on 1 ton and sometimes 3/4 ton trucks?
Just got back from a kickass week overseas, very next morning while looking at my truck, decided my current 285/60/20’s didn’t fill out enough so I installed 295/60/20’s and now I likadatires!
Better side wall protection too
New to me 2016 Silverado midnight edition 2 inch lift (I think ) air compressor. Haven’t owned a truck since I was 16 so it’s a big adjustment . Looking to do
some subtle mods nothing crazy
Pretty truck, don’t recommend doing anything being your first truck, just enjoy driving it, get used to its functions and abilities then it’ll just hit you.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
