Do a small lift, preferably a CST 4.5” lift, lose the 360 degree multi color lighting, then you’ll have a bad ass looking truck!
Edited by txab
Usually if I don’t like something of someone’s, I just scroll past it.   You have your preferences. Don’t try to push them on to others.  360 degree lighting?   The front has nothing but a bullbar with a light.  As for the others.   Plenty of people stop to tell me how awesome it looks.   Thanks though
  • Like 6
Do you mean parking sensors? This is a LT Z71 it doesnt have parking sensors
Gotcha. Didn't know the z71s didn't come with them. Still a very nice looking truck
Sent from my SM-N950U using Tapatalk
Z71s come with the sensors on the LTZ model, not on the LTs.
Just picked up this one last night 2018 Crew Silverado Z71. Had two GMC Sierra's so was time for a change. Putting the Mud flaps in tomorrow.
47571431_10155482023331525_8679903831749
47685224_10155482023371525_4386073903219
47575159_10155482023311525_3550159158726
  • Like 3
Nice, mine use to look like that ? time to modify lol us truck guys cant leave well enough alone haha
1 minute ago, 18SierraAT said:
Gunslinger that truck looks clean! nice work!
Thank you!! I just did black overlays on the z71 door sill plates today ( covered the red z with black one to match truck) im still tire shopping
Those Z,s came out nice.... those lights on top of the cap are a nice touch as well !
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
