On 11/13/2018 at 12:55 PM, retodd709 said:
Here’s mine
4 hours ago, retodd709 said:
Yessir, top is done in gloss black. Just waiting on my pinstriping to show up so I can finish it
White to start?  Figured that you bought a ME and wrapped the white parts.
Still looks good. Wouldn't have thought that a "two-tone" like that would look sharp, but it works and looks good.
Yeah it’s diamond white or whatever that pearl color is called nowadays. I got a 1/4” pinstripe color matched to the wheels to separate the black and white, and all the cheap looking grey pieces inside are wrapped in black brushed metallic.
10 hours ago, Fix29 said:
Sent from my SAMSUNG-SM-G890A using Tapatalk
What kind of grille are you running? And we’re you able to use your stock surround?
It's from EAutoGrille, they sell on Ebay. And it is available with or without the surround. I chose the insert which requires you to cut out the center of your existing grille.5e4089e37e3ed3bb86d5989d57a51d12.jpg
On 11/10/2018 at 5:32 PM, Ducky said:
2018 Silverado 1500 Z71 LTZ "Midnight Edition"
My best friend and I both got one.
Love your Midnight. I looked at one at the dealership. Its price was 41K. So I kept on browsing. Several nights later, I took my wife to look. We noticed the Midnight had just sold. THEN i really wanted one.  In the end I bought my 18 GMC. No regrets, but I admire the Midnights. Cheers!
The dealer advertisement for my truck.  Followed by the day I brought it home.  Followed by today.  Desperately needs a wash.  Added trifold tonneau, Bilstein 5100's all the way around (set on top notch), Go Rhino! RB20's and 275/70r18 Wildpeak A/T3W's
Look's Good - How do you like the RB-20 ??
Took me a little bit to get used to seeing them on the truck.  I honestly like the look of the truck without any boards better, but I was worried about destroying my seats without them.  I like them, but there are a few fitment things that could be better.  I am having trouble getting them perfectly level.  I'm a little anal about that stuff so it catches my eye when one of the gaps are off or the board doesn't sit flat on the mounts.  There is enough adjustment in the mounts that I think I can shim them with some washers to get them perfect, I just haven't had time to mess with them yet.    They are rock solid though and look like they will hold up better than the nerf bars that were originally on the truck.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
