On 10/26/2018 at 8:57 PM, LexusMate-GMCSierra said:
I went to get the oil change on my 2012 GMC 1500 Extended cab SLT and ran into my dealership salesman. I came home with this and got a free oil change for the 2012. A 2018 1500 double cab, 4WD, SLT. I added a spray in bed liner and tonnopro cover. Very happy with the new ride.
Damn.. quite the turn of events LOL!
"Honey, I am going to the dealership to get my oil changed"
*2 hours later*
"Honey, come look at my new truck!"
2 minutes ago, Deadpoollane said:
That looks good. Did you paint or powder coat the chrome center piece under the bumper?
Plasti dip than paint, it’s a hard part to get off
2018 Silverado 2500 HD Duramax/Allison Z71
Ice Metallic Silver...
Just changed the emblems...Can't stand Gold.
Did Vinyl!
I may buy another set of front and rear emblems and paint them.
I can't find anyone that sells red.
Everyone has black or silver.
2 hours ago, Deadpoollane said:
You mean the truck, right!  :D
Did Vinyl!
Rivercitycreation.com
Took me a bit to find these guys but they will customize with any colors you want.
  • Like 4
51 minutes ago, ducklawyer said:
More pics? Set up?
See if this link works - if not, my original post is on page 619 of this thread.
I had no idea until today they are making a 2019 LD model that is still a K2 build.  I took mine in to try to get the remaining squeaks out of the dash area and they gave me a 2019 Silverado so I was really excited I'd get to try out the new style to see how I liked it.  Then I see it's an LD and find out they are still keeping our build style around in limited trims all with bench seating and double cab from what this article says.  But if you really hate the new style but want a 2019 you now have an option as long as you dont want bucket seats, crew cab, or ltz.  How did I not hear about this before driving one?  Haha
https://www.off-road.com/blog/2018/07/04/light-duty-lucky-draw-2019-chevrolet-silverado-1500-ld/
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
