Been a lil bit since I had been here.  In October I purchased this camper and truck pulls it fine since I added air bags to the rear to eliminate the squat.  The other picture was taken in one of my favorite places being Skyline Drive Virginia and at my favorite overlook.  Taken with my phone, but would have been so much better if I had my camera with me.1601167956_SkylineDriveDecember2019.thumb.jpg.4d369696287334a9034f7db108d8e690.jpg798004617_trucktrailer.thumb.jpg.32ee51a5bc4a5cbb32a2aecf2febdfdb.jpg
What size tires? Any trimming?
315/70r17s. Yeah some metal trimming
On 9/18/2018 at 2:15 PM, luckyshotbrooks said:
Yes it has the new upper control arms. The shop I went to said it wasn’t necessary but that they recommended it. I decided to go with it since it is a brand new truck. Didnt want to give them any reason to try to get out of warranty.
I know this is an old thread/post but I was thinking about going with the same setup and was wondering if you had any issues with rubbing? Thanks in advance
2018 GMC SLT Z71 Standard bed, performance tuned 6.2. Fuel 20x9 +1 offset, 33” BFG KO2’s, CST 4.5”-5” Lift with front CST Coil Overs and CST rear Piggy Backs, front CST Skid plate, RollNLock Bed Cover, G2 Rear Diff Cover, etc etc etc...
8529eddc4540602bd949e5c7aab1e457.plist
cb2545d6b1fd1499d0fe7013405565c9.jpge185cd8493d7ea6662c5aea6a3b8bb39.plist
Sent from Above
  • Like 4
Sent from Above
One of my all time favourite rigs on here.  You did an awesome job building this this truck.  Almost makes me wish I never got a Denali Ultimate....oh well.  Looking good bro...?
One of my all time favourite rigs on here.  You did an awesome job building this this truck.  Almost makes me wish I never got a Denali Ultimate....oh well.  Looking good bro...[emoji106]
Appreciate it, it’s definitely a keeper.
Sent from Above
Wow, what a nice collection of trucks! Both lifted and lowered
New to join the forum, been reading posts for a while. I'm Brian from New Jersey, here's my truck
2018 GMC Sierra 1500 All Terrain double cab:
Summit White, Black interior, 20% all aroundWeather Guard tool box, Magnum headache rack, Mud flaps, stock 20" wheels 275/55/R20.
Welcome Brian, and congrats on your new truck.  Very sharp and clean looking ride.
Wow that second pic looks almost exactly like my complex. Hope I can remember to snap a pic today when I get home.
traded my '16 silverado in for an '18 Sierra.  loving the GMC and the 6.2L so far.
Edited by mdf21
Snapped a quick shot headed to the airport for work... -26 degrees out with a 4:00pm sunset! Gotta love January in interior Alaska...
lol yeah classic garden complex look
thank you. have had it almost a year  finally had time to join and post something
something about these and the snow
This is the only snow this thing see's. Snow doesn't bother me, it's the salt they pave the road with in the winter here.
I don't care what people say, she sits in the garage during the salt season.
    Enduro73
    Enduro73
  • Who's Online   5 Members, 1 Anonymous, 1,387 Guests (See full list)
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
