The guys at djm said that there leaf perch moves the wheel back enough to allow it to all work i guess.
Someone on here said that gm is using a different driveshaft then what was being used on early trucks, i installed a mcgaughys flipkit on mine and didn't need to shorten the driveshaft but another member on here with the mcgaughys flipkit had to shorten his I guess you won't know till you do it
Edited by 2014blacksinglecab
do you have any pictures of the airbag helper kit?
While I installed the wheel well liners today, I shot a picture of the McGaughys helper Bag kit for their 6' flip kit.....
After shortening the driveshaft, everything went together great. Truck rides better then stock......
OK I want to drop my 14 Sierra in the rear 2". If it is slightly higher than the front I am fine with that I just don't care for the extra high look in the rear. So do the mcgaughy's fit and not squeak and not cause driveline issues and not vibrate if that is the only change that I make ? After removing the hitch do you have to fight the spring to remove and reinstall the bolts ? Any issue at all with the Mcgaughy brand ?
Thanks,
Yotaman
Thanks,
Yotaman
I just installed these this past weekend on my CC SIlverado. After the hitch comes off it's pretty straight forward. I didn't have to fight the spring but I did have to roll the bed seam to get the spring up far enough to take the top bolts off. Overall though not a bad install. Once you get familiar with doing one side, the other will go twice as fast. So far all is good. No squeaks or vibrations. Here's a before and after.
IMG 1560
Thanks Flt23 that looks way better dropped than stock. What does rolling the bed seam mean ? Bending sheet metal out of the way ? any pics ?
Sharp wheels too BTW
Thanks,
Yotaman
Edited by Yotaman
3/5 drop
Enviado desde mi DROID4 mediante Tapatalk
Are those Tahoe wheels ?
Thanks,
Yotaman
Yes, there is an area above the spring where some sheet metal comes together from the bed that you will have to bend out of the way. I'll see what I can do to get some pics for ya. Thanks for the compliments!
3/5 dropEnviado desde mi DROID4 mediante TapatalkAre those Tahoe wheels ?
Those are the new 20s they come on Texas Edition.
I have found plenty of pictures of trucks with the front ends leveled but can't seem to find ANY of the new Silverado or Sierra with a leveled rear suspension using 1-2" drop shackles. Anyone have any pictures?
Here's mine with the 3" Belltech kit (blocks removed) I think it's perfect. And no, I did not trim my bump stops and I'm having ZERO issues with it. Lovin' it!
Edited by HMcCaleb
Ok, I figured out to post a picture, but now I can't figure out how to delete this message. It's only letting me edit this box, not delete. Sorry.
Edited by HMcCaleb
For those who put a 2" lowering shackle and modified the bump stop on their 2014 silverado, did you have any problems with the shocks or any problems at all?? Would you recommend use lowering shackles??
I cant decide if i want to do this or not. I just dont want to run into problems
I used to the Belltech 3" lowering shackles (includes the removal of the factory block) and I did NOT trim my bump stops. I have over 1,000 miles on it and no issues at all.
I have 2" McGaughy's drop shackles and removed the factory block, cut the bump stops to the last "ring" below the bump stop cup. Have no problems with the factory shocks bottoming out on travel and have very rarely even hit the bump stops. No vibrations.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 270 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
