I used the Belltech drop shackles and I removed the blocks, for a total drop of 3", and I have no problems. Smooth as butta'!
That's wat I'd like to do. Maybe one day. Maybe just pull block for now.
Sent from Tapashit
Did you are the installer have to fold the seam on the bed with the BellTechs ??
Yotaman
Hello all, I have 2014 Sierra 2wd, 1500, CC, standard bed. I recently installed a 4/6 DJM kit and have experienced some issues. First the stock 285/45/22 tires rub the fender well ALOT, and there is vibration that gradually increases from about 55 mph on up as you accelerate. I'm going to put smaller tires but want to fix vibe issue first, dont want to change to many things at once. The truck always had a flutter when taking off from a stop and still does. To be honest I dont even know where to start. I dont think it is pinion angle as the installer has checked it twice and says it is spot on. At least the installer has been good about it so far and willing to help but not sure what the fix maybe. Any ideas??
Any pics
Sent from my SM-T210R using Tapatalk
Sorry not real hip on how to post pics.
Bayou, you said you were having the vibration issues before? I know a few shops in here have been installing 2pc drive shafts from the previous body style and it has been correcting drive line vibration issues.
Brent thanks for the reply, yea the slight flutter when taking off from a stop has been there since day one. What has me more concerned are the vibes at hwy speeds. I have read a couple places were on older trucks this was corrected by basically installing a bracket that lifts the carrier bearing, however i cant find a kit like this for a 2014 GMC.
That was the good thing about previous gen trucks, 2 piece drive shafts... Then the '14's have very little play on top of one piece, so it's very easy to get it in a bind.
Yotaman
I had to flatten it totally out on all 3 2014 trucks Ive lowered.. Mine was worse then the other two, I ended up cutting mine off, because even flattened the damn top bolt wouldn't come out.
i lowered mine with the belltech 3 5 kit and i seem to also have that vibration rubbing sound in the rear as soon as i get closer to 50mph, installer notice that also and he installed a shim on transmission mount i believe? i couldnt quite understand him since they been working on it for like 10 hrs trying to figure it out, as this time i have no clue what to do as either as the shop who lowered the truck. [/url]">http://http://s801.photobucket.com/user/rang3l93280/media/1658650_916903208335602_3359907531639276262_o.jpg.html'>1658650_916903208335602_3359907531639276
I'm looking for the best way to lower the rear of my 2014 2WD 1500 about 1.5". That will still give it about a 1.5" rake which should mean level when I'm towing. I considered drop shackles but was reading about removing the rear lift plate that's between the axle and spring.
My question is can the leaf spring sit directly on the axle or is some sort of spacer / bushing required for proper alignment and isolation?
I took the blocks out of my 2010, 2013 and now out of my 2014. Take the blocks out and use the same ubolts and put
6 washers on each ubolt stud, there is not any change in the ride. The blocks are a lttle over one inch but it looks like
you lowered it two inchs. The bottom line is the trucks looks a whole better. I am 71 years old and it is easy to do for an old
man, my 5 year old granson can do it.
So after I get back from vacation I plan on ordering a kit for my 4wd Denali, the truck that made me decide to lower it is an all terrain 4wd with a 4/7 drop thinking I might follow his lead any suggestions?
So far I've talked to Mcgaughys and Belltech. Belltech told me they haven’t tested anything on the 4wd yet and the don't recommend trying to use any of their 2wd products on a 4wd. Mcgaughys has a 2/4 kit but I personally don't like it, They did tell me that the rear parts are all the same but they don’t have anything available to get the front lower than 2 inches. If anyone knows of anything else available I'd like to know
So far I've talked to Mcgaughys and Belltech. Belltech told me they havent tested anything on the 4wd yet and the don't recommend trying to use any of their 2wd products on a 4wd. Mcgaughys has a 2/4 kit but I personally don't like it, They did tell me that the rear parts are all the same but they dont have anything available to get the front lower than 2 inches. If anyone knows of anything else available I'd like to know
He's using the mcgaughey 2wd adjustable kit, I confirmed it with him he notched the rear frame however and set up a helper bag for towing, he's got it on the full 4/7 drop
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
