Thanks for the info. Now I just have to get around to doing it. I've had the shackles for over a year now.
Lowering a 4x4 has been talked about but I haven't found anything specific on what kits people used. Rough Country is probably cheapest along with quality not being the highest on the list. I was looking at just doing the Shackle drop but feel its not much of a big change. Being in Michigan and having random winters with low snow levels one year and high snow levels other winters, I'm not sure i want to go much lower than where the front sits now.
What are people with 4x4's going with? Shackle and block removal or kits?
Kit that I was looking at was the Mcgauphy 2"/3.5" drop
http://www.mcgaughystore.com/2014-2015-chevy-silverado-1500-double-cab-2wd-4wd-2-3-5-drop-kit-34123/
What are the pros and cons with this kit. I can see the front having adjustment issues for alignment since it lowers just the spring position.
Also I want to run OEM style 22's and need to retain my towing ability.
Hey all.
New to the forum and just bought a brand new 2015 silverado lt double cab 4x4. Figured this would be a good place to start asking questions. Going to order the 2in drop shackels tonight, and probably install some time next week, anything i should know before installation? I know i'll have to drop the hitch assembly and bend those bed tabs out of the way. Any other tips or tricks to make this project go smoothly? Any help is greatly appreciated. Thanks in advance!
-Mike
attached is a pic of the the new ride :chevrolet::chevrolet::chevrolet::chevrolet:
Remove the rear blocks.
044DF323-2108-4B86-86D9-84803560B327_zps
So you can remove the blocks without replacing anything with them?
New to the site myself, but finding all sorts of good info on here. Just got my rcsb lowered and color matched. Mcgaughys kit, 5/9, riding on 285/35/22s
8 24 2015 022
I've been working on my 2015 Sierra SLT and thought I would post a few pics of it so far. I started with a Borla rear exit touring system and Belltech 3/5 drop, added KMC 22 inch wheels with 305-40-22 Grabber UHPs, a BackFlip G2 Tonneau, a Bedslide 1000 SE, 30% tint all the way around and Putco fogs and backup bulbs. I took off the factory oval tube running boards and temporarily installed a used set of ABS boards off a Yukon. I don't love the look of them but needed something to stop my 9 year old from wearing the paint off my door sills. I have purchased a set of the AMP Power Steps but now I am thinking they may extend down too far. Does anyone have the AMP Power Steps on a 2014 or 2015? If so, how far down do they extend from the body? Would you mind posting a close up picture of them extended?
I have already purchased a bunch of stuff for the next stage, I just need to get the time to install them. I have Hellwig front and rear sway bars, an AirLift 59209 Slam Air kit with a Wireless One compressor kit, A K&N cold air intake, Murimoto Sierra Spec headlight kit, Rigid Hi/Lo driving lights and Rigid diffused flush mount backup light kit. When I install the sway bars the Borla pipes will be right in the path of the rear bar. I love the sound of the Borla touring muffler so I plan to cut off the back half and have a local shop custom bend some new pipes that exit behind the rear wheel, pointing out and down, but tucked up tight to the rockers. A pair of the GMC 23238760 tips should finish it off nicely.
Next stage will be a programmer but I have not decided which one yet. If anyone has a programmer they are really happy with please let me know which model. I hoping to find one that will firm up the shift points. The transmission seems to have a light slip between the first few shifts. The dealers says they all do it but I still prefer a firmer shift. I can't help but think a firmer shift would mean a better life-span for the transmission too.
IMG 7183
IMG 6468
IMG 6467
IMG 6465
IMG 6464
All those pictures, your truck is dropped only for 3" front and 5" rear?
I'm looking for help in regards to my Stabilitrak. I lowered my 2015 Denali 1500 2/4 with McGaughys kit. It's got Magnetic suspension with those little level control boxes. We bent the rods in the rear to match the factory angle like the kit said to do. Mr. McGaughy and staff won't answer calls or return messages so here I am. At about around 5-20 mph turns on side streets or parking lots the Stabilitrak light will flicker a few times and cut throttle until I straighten out again. I have 24" wheels on the vehicle. Just had a wheel alignment. GM just reset my BCM (body control module) today as well and it's still not fixed. Any help would be wonderful. Sorry for the double post. This one has better info. Thanks!!
Hey Dan, Curious if you got this sorted out. I talked to McGaughys several months ago and they did not know when they would get MRC kits to production.
No I have not,
I've called McGaughys many times and no one returns calls. Funny they say they haven't made a kit for this truck yet when I ordered it directly from them. Also my boxes say McGaughys all over them. Magnetic suspension is garbage imo!!!
No I have not,
I see the '15 drop kits with MRC are listed as "coming soon, call for info" but the 2/4 is only for 2WD. http://www.mcgaughystore.com/2015-sierra-1500-denali-lowering-kits/ Starting to get a little more excited. I juts hope I can still add bags for when the trailer is pinned up.
Did you get the '14/15 kit intended for non MRC shocks? Was there any shock relocators or sensor rods with the kit?
update: drop shackles installed and blocks removed. pretty happy with how it came out. some pictures make it look like the ass is lower now. see for yourself. i dont know why those pictures are turned, any info on that? haha
post-147482-0-47254600-1440861992_thumb.jpgpost-147482-0-08405700-1440862047_thumb.jpgpost-147482-0-99184300-1440862054_thumb.jpgpost-147482-0-84716500-1440862060_thumb.jpgpost-147482-0-45257600-1440862065_thumb.jpg
Nice truck, mine is at 4/7. How much you pay to get it color matched?
I've decided I'm getting rid of my lift, ordered some bilstein 4600 for the front, going to go back down to stock height and I'm removing my rear blocks. I think it will look good with my 22's.
Can some one confirm this, on the 2014-2015 sierra, the back wheels doesn't line up with the fender evenly. On my 2015, the driver side wheels stuck in about half an inch. On the passenger side is about even with the front. I though it was just mine, but i got a loaner for the day and I check it out. It's the same thing. I'm not sure this is happening to every GM truck or not. It might be the cause of all the vibration that we're having. Please check. Thank you.
I noticed this on mine the other day after I removed my rear blocks.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 230 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
