Great looking truck. Could you snap a pic of the rear pinion angle? I have a slight vibration put in 6° shims but I think 4° would have solved it. Thanks
Sent from my SAMSUNG-SM-N910A using Tapatalk
A pic won't do anything for you. Every truck is different so add angle or take it out and see what your truck likes.
RT
I know that just like to see. I tried 3° then 6° and it still has a very slight vibration. I had it at the dealer for a recall and they said my shims were in backwards Wichita I know is wrong. I have the pinion tilted down in the front and tech said it needed to be pointing up. I don't guess they deal wit dropped trucks very much I have been doing this for 25 yrs and this is the first truck that has given me any vibrations.
My guess is your transmission is pointing down, which is why the tech said pinion needed to point up. You probably need to put an angle finder on to see what's going on.
Thanks that's the next step I put a trans spacer in and made it worse. I'll do more checking this weekend
you need to measure the angle and not just guess and throw parts at it. You can download a free application on your smart phone for angle finder and measure it, believe it or not its pretty damn accurate. Get the truck on level ground and measure the angle at the slip yoke at the front of the driveshaft and then the yoke at the pinion. That will tell you how far you are off. For example I measured my truck before and after just to see the rate of change (every truck is different, my numbers can not be relevant to anyone elses truck). Stock my angles were 7* at the trans and 8* at the diff. 1 degree high, after it dropped to 4* after a 2 inch drop (already had the blocks removed). So mine is off by -3*, I have 0 vibration issues and I have not bothered with it
Totally understand I guess being 4wd makes a little bit of difference. I will do more checking today or tomorrow thanks.
Ok so I measured the angles at the transfer case where the u joint is its at 7° and the rearend is at 3°. Does this mean I need to add 4° more or would I replace the 6° with a 2°? Damn this is confusing lol.
If you already have shims in the trans or rear end id take all of them out and start over. It is going to be much harder to get the 2 close if your adding and removing shims. Depending on how far your drop is you shouldn't have to mess with the transmission angle at all, it can all be made up with the rear end since that's what is rotated down when you lower it
Ok took shims out now trans angle is at 6° and rear is at 3°. So I'm thinking I need a 3° shim to raise front of pinion upwards?
Ok thanks I just thought the pinion needed to be tilted downward but if I match the angles it will be slightly upward.4c98e603f548435e98908fdfbba40978.jpg
Really all your doing to eliminating your vibration, a few degrees wont affect anything except how the gear oil is distributed in the diff. Have you driven it with it being 3* off yet? I know every truck is different but I am 3* off and have no vibration at all.
Yes I drove it this morning to work and the vibration is still there gonna pick some shims up today and put them in this afternoon.
post-161693-0-00587200-1472477735_thumb.jpg14 Silvy -
Don't know if this helps but here is the angle measurement at my rear pinion.
It helps him some, would need to know the tranny angle is well.
You want it to be off some for pinion movement.
Edited by wuznme
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
