I really wish I could get the rear just a little bit lower, but I do not want to do a axle flip. I guess the height I am at now is just fine for me especially still being able to use 4wd.
Now I just gotta decide weather or not to keep the 20's ltz tire or bump up to 22's
I have the 3" shackle in my truck with the block still in and there isn't much clearance between the bump stop. With the block out i would have to cut the bump stop or get aftermarket one.
There is no such thing as 3" shackles. Shackles allow you 1" or 2" drop and removing the block give you another 1"
I've read the install instructions on the belltech website and see what everyone is talking about. Had a look underneath and the block is gone. But my truck sits half inch lower in the back so I might put a half inch block in to get it level or even a very small rake. Not a fan of the squat look and I can't un see it lol.
I think I need some 22's now.....
I agree 22"s would be hot,I'm with you with the drop I really don't want to do a flip kit at this time.I think I will have to go the route you went till I have the nerve to do more.
If your serious about the 22"s consider any of the newer GM ones they all look good.
I happen to have a Belltech 6401 shackle kit if anyone is interested. Good for 2 or 3 inch drop. Its new in Box.....PM me...
I happen to have a set of Belltech 6401 shackles, and 2ea Belltech 2212FF performance series shocks if anyone is interested. Only used for few months.
I have tried searching, but cannot find if instead of removing the gas tank on a crew cab for a flip kit, can the bolt just be cut off and a new one stuck in the other way? I want to do a 4/7 drop on mine, but cannot drop the tank. I have installed drops on most of my trucks and just don't want to fork out the money to have someone else do it.
I have done this exact thing on a ford, just cut it off and reinstalled from the outside in. I did the flip on my 2014 RCSB and never removed the tank, i was able to shuffle the rear end to the passenger side enough and get the driver leaf spring around the outside and under the axle.
^^^ This
Edited by wuznme
I have read the entire thread but i couldn't make my mind set on what to chose for my truck so here goes ,
2014 chevy silverado 1500 z71 with aluminum front end
i want to lower it to 3/5 at least , don't want any spring or strut options because alignment issues
DJM or mcgaughys who ride great and don't ruin anything with 4wd stuff they didn't specify any lowering options for 4wd trucks
Belltech ride great as far i can used in another truck but alignment is an issue even if do it right it will need another after a while
Your aluminum control arms limit your options like they did for me on my 2015 Z71, meaning no spindle options for you unless you are willing to go and buy some steel control arms (which isn't all that expensive actually). If you want to go down 5" in the rear you are definitely looking at flipping the rear + cutting/removing the rear bump stops. Depending on how much weight you haul/tow, you might be able to get away without having to cut off the rear bump stop brackets.
Only one that will give you a 3in drop without struts/springs is the DJM control arms, most a spindle will do is 2" and I've heard the McG spindle is more like 1.25 but no first hand knowledge.
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
