Please let us know how the 8504's ride. I'm dropped 2" in the back, still running the stock shocks.
Well, I can only compare them to the Ranchos, and I can tell you its a much plusher ride. The Ranchos were just gross, bouncy, made the truck feel like it was twisting all over the place. Feels much more planted now. And yeah, its a Z71 4x4 done up as a street truck, so what? Haha. I couldn't find a an SLE 4x4 anywhere
Does anyone know if this bushing is supposed to be put back on with the Belltech 25004 drop strut? The instructions say to remove it with the cup, but the install just says to install the cup and doesn't mention this bushing/ spacer. The picture also looks like it shows more thread during assembly than I have with the spacer installed.
Any help is appreciated.
Thanks.
Edited by Mh167002
I am talking about the spacer sitting on top of the bump stop in the picture.
I got ahold of Belltech today and they told me to leave the bushing out in case anyone ever wonders as I did.
Secondly, I have it all back together and have "service stabilitrak" screen followed by "steering assist reduced drive with care" screen after. Install was easy and I didn't have to unhook anything besides the sway bar end links.
It is strange because it needs aligned as I knew it would, but I couldn't believe the steering wheel was pointing around 10:30 to go straight.
Could this cause my service screen or do I need to look elsewhere? Has anybody else had this installing belltech 2" drop struts?
Yes. It is A 4X4 Z71.
I used Belltech 25004 Drop Struts to get 2 inches lower in the front and Belltech 6400 2"drop shackles to drop the rear followed by removing the factory lift blocks.
Here is how it sits right now.
I got it aligned today and he performed a reset of the steering sensor and my stabilitrak is working fine. The ride is a lot nicer with these struts compared to the stock Ranchos.
Okay..... if I missed it forgive me but I searched this thread and found nothing definitive. I have a 2015 4x4 with steel spindles and control arms..... have people successfully installed the Belltech 2509 spindles on those or not? Belltech says 2wd only but then other sources flip flop on it. I mean worst case scenario is I take it apart and find out lol.
During my research, I learned that the Belltech 2509 spindles should only be used with steel control arms (which you have). I was not able to get a solid answer as to why they do not recommend it for a 4x4.
Guess it depends how low you want to go in the front. If its just 2", then Belltech BEL25004 struts worked fine on my 2015 4x4. It actually measured 1.75" lower in the front (need to take in to consideration that lowering the back like I did pivots the nose of the truck upwards a little)
I don't want to touch the struts and 2" is all I am going to drop it. This should be good then!
Sent from my SM-G900W8 using Tapatalk
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
