I have a slight lean on the drivers side (like all chevys) does anyone know of a strut spacer that's 1/4"- 1/2"? To fix this lean
Yep I made one for my 14 for the lean. Actually made a few 1/4 thick worked great.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I have a question for you guys, at what amount of drop in the rear do you run into driveshaft bottoming out in the transfer case or transmission?
Drive shafts are not a uniform length. Some people have had to cut and rebalance them and others haven't. My guess is they use different suppliers to source them.
You able to make me a few? I don't know the arm ratio. I'm 1/2" differance in the front and obviously is more when I sit in it. I yhink the ratio is 2:1 but not sure
Yea I got some send me your address and I'll send you some.[emoji106]
I've been talking with djm for 2 days. The 16s have dofferant ball joints so they are teyung to source the right one. I have a 16 and I'm just waiting on them
Any updates?
Yes I found I had the first round of 2016 arms which are same as 14 and 15 so I got the kit
How low are people going in their 4wd RCSBs? Will we run into front end issues like other AWD and 4wd cars/trucks?
2015 RCSB Z71 4x4 here, and haven't had one issue at all with my 2-4 drop. However, I am thinking about dropping the front a little more and would like to learn more about doing an air bag system for the rea only, so I can run level when I want to, and lift it up when I want to trailer or carry heavy loads.
What's the best way to get 1" more drop. I have a 3/7 kit waiting to be installed but I have a feeling I'll need to go 4/7
I would say the McGaughy's struts. That's what I'm gonna put on mine just gotta make sure I have clearance with the front axles.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
