I did the full McG kit and went 4/6 at first but brought it back up due to rubbing and not wanting to notch the back, then I switched the rear flip to the DJM to get the pinion adjustment but probably didn't need to because it looks like I am probably dealing with the bad axle issue. My own fault for installing the drop with 50 miles on the truck. It was probably present before the drop but I was convinced it was a pinion angle issue so instead of messing with shims I pulled the McG brackets for the DJM's for the adjustment the provide.
How is it custom?
Technically all off the shelf, but it's not a kit. I used McGaughys rear axle flip as well as their adjustable struts. I also bought a set of 2" drop coils, and all the parts for the strut assemblies (down to the U nuts) from a chevy dealer down the road. I used belltech rear shocks.Have a set of upper control arm bushings coming from Napa this week. Will be installing those to try to get camber back to an acceptable amount.
Anyone remove the overload springs in the rear to get another 1" of drop? Ive done 2" shackles & removed rear blocks & doing this should put the rear around 4-4.5" . I know it will take away payload ability but I do not tow or haul with my truck.
Edited by MM98
Little over 1/2 and nets about 7/8 of drop. truck doesn't ride very good like this though..
2" drop shackles and a rear block delete will net you about 3.25" of drop..and that is ONLY if your shackles are actually a 2" drop. My McGaughys shackles were about a 1 3/4" drop. Hope this helps!
If you have done a flip kit removing the overload spring will not lower the truck any because it's on the bottom of the spring pack. If the springs are on the top of the axle it will lower it a little.
RT
You're going to want some Ride Tech RQ or HQ shocks go to the web site with your measurements, they will have something.
I actually realized I won't know the length yet because I just bought rear shock relocation guess I have to wait
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
