Truck looks great & really like the stance!!! I assume you had to align it after lowering the front?
Question for you guys. I was looking at Rough Countrys 2/4 drop kit & all you essentially do is relocate the struts to the under side of the control arms using the provided 1/4 plate. Can this be done without using the plate? I ask because Ive lowered the rear with 2" shackles & removed the blocks & want the front a lil lower now. This seems like a free way of doing so. Also, does anyone see any negatives fron relocating the struts like that? Seems like it would put a lot more stress having the struts mounted like that, thanks guys!
Use the McG spindles. I've had them for 15k, no alignment issues and truck handles like stock. Only issue is you lose some turning radius.
I,have the bilstien 5100 shock in the rear at 7" I'm going to go 8 soon. Will I be OK with it or should I get a shock extender
Seconded. Great spindles, easy to align, great ride.
Think you will need the extenders or shorter shocks. Get under and look how much of the shaft is showing.
I knew I shouldn't have put the shock boot on
I agree with Wuznme... Shock extenders would be the cheapest route....
Yah I'm going to get shock extenders. Coming to oldest some parts before I notch in February or march
Willyism,
Can you elaborate on what you did to get the front 2" drop with your aluminum front suspension. I was going to order that same JDM kit but would rather go your route. Could you elaborate and do you have any pictures?
Thanks,
It can be done without the plate with no issues... I have a 4WD and DJM is the only company that claims that they have a kit that will work (2515-2/4). This may be true for some but it wasn't for my truck. I bought the kit and the control arms did not have clearance at all. After calling them, the said due to my truck having the cast aluminum spindle, I would need to shave the lip of the spindle and change the ball joints.... Needless to say, I packed it up and returned the kit.
I relocated the strut without the plate which gave me my 2" drop in the front along with shackles, shocks, and removing the block to lower the rear. I pick my truck up on Tuesday and I've already driven it 400+ miles with no issues and it still rides like stock.
Willyism,
Thanks,
I think he just moved the bottom strut mount to under the control arms. I would buy the 2" DJM control arms I have a 4x4 with the aluminum front suspension and I'm running the 4" arms and a belltech flipkit out back set at 6. I don't have any issues with 4wd and rides great (for being dropped)902ac367a978c383dc0cbd0686d0d0d9.jpg
Sent from my SAMSUNG-SM-N910A using Tapatalk
Willyism,
Thanks,
14Silvy is right about just relocating the bottom of the strut to the bottom of the control arm which is how rough country mounts all of their lowering kits so it is safe.... However, as I said in my previous post, I have a 2016 and the DJM Control 2" arm did not work for my truck 4WD Silverado so do your research on your truck and call DJM prior to purchasing those control arms. I had to send the kit back after about a 30min 3 way call with Jeff from DJM.... I was refunded but it still cost me $180 buck to ship the entire 2515-2/4 kit back to DJM due to the weight of the entire kit and warning, based on my experiences this past week, DJM's customer service sucks...
^^^ Agreed!!
I called them 3 different times about 3 different issues with their flip kit and the response all 3 times was "wow never heard that before" even sent them pictures and they still had no answers. I boxed all their shit up and sent it back.
If relocating the mount under the control arm (did this for about 11k miles) I would suggest some aircraft bolts just to be safe and on my CC 6.2 it netted 3-3/8 of a drop.
You.might need camber bushings if you do that. I will be selling my mcg struts somewhat soon and swapping to viking coil overs
With 2in drop in front may not need offset bushings, I needed them with 3-3/8 drop as the alignment was still about 1° off.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
