7 minutes ago, Nasty said:
Qa1 in the rear. Which made a huge difference. And Vikings are being installed in the front after the rain stops
I'm gonna have to jump under there and see where my stops sit compared to yours. I didn't think the Belltechs were that soft, but now I need to consider alternatives. Helpers definitely wouldn't hurt either.
Now that it's down, going back up isn't really all that fun.
Well if you're notched. You should be fine. I don't think you're hitting the frame. I think your diff is slamming the bed support.  I hit the bed support before I hit the frame and I'm not even notched
Tighter radius than a lot of cars. Lol.
Nice video.
Still drives like stock, if not better.
Not too shabby for a half assed video shot from my phone lol
I'm down to 2/5 now.  the front is 1/2" higher than the rear.  My drop spindles will be in next week.
I,think it's level. The rear fenders are actually lower than the front. If that's how you're measuring
Looks great man. Mine 2/4 but I want my back lower.
Has anyone here lowered there truck with an air suspension? I'm looking to lower my 2015 Sierra but honestly I was trying to avoid using the flip kits. I would really prefer to have it bagged. Could anyone give me some info on there own setup or maybe on some kits you've heard of?
Thanks.
Thanks.
There is a kit of some sort.   But it's a lot of work.   And what's wrong with a flip kit?
So what's the difference between a 6.5 and 8" rear drop? An axle that no longer aligns with the notch.
Yeah, I'm kinda frustrated.
It should align just fine    are you having issues ?
The slight change in angle of the leaf places the axle slightly further forward when the suspension is under load, and it no longer lines up with the notch. Axle is hitting the frame right where the notch begins.
The notch also may not have been perfectly centered to begin with.
Edited by Stressin
1 minute ago, Stressin said:
The slight change in angle of the leaf places the axle slightly further forward when the suspension is under load, and it no longer lines up with the notch. The notch also may not have been perfectly centered to begin with.
What notch?
12 minutes ago, Nasty said:
What notch?
Street Edge (bolt-on). Belltech's were backordered.
Edited by Stressin
Those with Drop strut's or drop spacers for the strut's have any issues with alignment after? I'm still up in the air about levelling or lowering my truck and I've thought about getting Bilstein 5100's and installing McGaughy's 2" drop spacers on the 5100's set at stock. That way if I don't like it I can just switch to levelled, with out having to order more parts, may even just use the stock struts first. In the back I'll remove the block and install a 2" drop shackle. That way if I want to go back up it's an easy reversal...
My truck aligned fine   I'm at 4" drop in front
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 737 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
