11 hours ago, Daly said:
Those with Drop strut's or drop spacers for the strut's have any issues with alignment after? I'm still up in the air about levelling or lowering my truck and I've thought about getting Bilstein 5100's and installing McGaughy's 2" drop spacers on the 5100's set at stock. That way if I don't like it I can just switch to levelled, with out having to order more parts, may even just use the stock struts first. In the back I'll remove the block and install a 2" drop shackle. That way if I want to go back up it's an easy reversal...
I have 2'' drop shocks in the front and my alignment is in spec. I think I'm right on the max adjustment for camber though, if I remember correctly.
Down 4.5 in front with spindles, struts, and springs...still aligns within spec.
I figure with Spindles the alignment will be fine, I just wanted to make sure a 2" drop from a strut will be fine. I had my feelings it would be, as it's really no different than going up, there must still be some adjustment. Just wanted to make sure I wasn't going to be getting into UCA's or anything. Thanks guys...
Finally installed my shackles this weekend. Not completely level... I'm debating on dropping it more. 5b72223bd1397abcee0f0486d1d82ef0.jpg
Also trying to get mounting hardware for my rear fender liners. No way I'm giving GM they much money for that stuff [emoji23]
Also what's your driveline angles looking like when you pull the blocks on the axle? Any degree wedges needed?
Just pulling the blocks wouldn't change enough to insert shims, but blocks in combination with shackles might.
On 3/23/2018 at 9:48 PM, Stressin said:
The slight change in angle of the leaf places the axle slightly further forward when the suspension is under load, and it no longer lines up with the notch. Axle is hitting the frame right where the notch begins.
The notch also may not have been perfectly centered to begin with.
Just to follow up on this:
The notch was definitely not centered to begin with. I put the 1/2" lift shackles back in and jacked up the differential to get a better idea of what everything looked like before I switched to the 1" lowering shackle, and it's the same. Working with the installer on a solution.
Blocks/shackles is 3", you lower it that much under load or when towing. If that causes a pinion angle problem there is an issue. No problem with mine...
Sent from my Pixel using Tapatalk
Yeah I just got the shackles in this weekend. Wanted to make sure I didn't need any degree wedges before yanking those blocks
I'm down to 2/5 now.  the front is 1/2" higher than the rear.  My drop spindles will be in next week.
Nice!
Sent from my Pixel 2 using Tapatalk
Any chance yall recall the socket size on those ubolts? About to pack tools up from work to carry home
21mm
21mm
Sweet thanks. Looked up the specs looks like they're torque to yield. Gotta get new ones?
everyone reuses them
I reused mine. Probably gonna get new ones when I install the caltracs though... Torque to yield 3 times is a bit much lol.
Sent from my SM-N950U using Tapatalk
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
