Drop springs? Where from and what was the cost?
Thanks guys, I couldn't be happier with how it turned out.
I got them from suspensionsuperstore.com they're part number MXT-251520-8 they show as 2" drop coils, but that's for crew cab trucks and on a regular cab will be a 1" drop. I paid about 120ish for the pair. I don't remember exactly. I try to forget the cost as soon as possible... Hurts less that way lol.
Sent from my SM-N950U using Tapatalk
Is anyone using the Inez Hotrod and Customs front control arms?  They tell me that the upper control arm corrects caster and keeps the wheel centered in the wheel house.  5aac43e86b488_controlarms.thumb.jpg.fcc0b416ed0879fc12353699cb2df25d.jpg
Edited by qwank
OK, so when I first put my truck back on the ground, the springs and spindles totalled 3". But I just remeasured and the front has settled to 4". I'm not sure if I wanna raise the front back up 1" or lower the rear another 1". I guess I'll have to crawl underneath and see what my cv angles look like.
Lower is better
23 minutes ago, lovelessjl said:
I like the way you think
I stated at a 3/6. Now I'm at a 4/7.  Now I want 4.5/8
Yeah, lowering the rear another inch is definitely the easier way to go. Looks better too, I just wanna make sure I'm not gonna destroy the cva axles when I install the turbos.
It's not fun unless stuff breaks becsuse then you can "make it better"
I bought the kit last August but have not yet had a chance to take it in to get it installed.  Too chicken to put it on myself.  I am looking forward to it though.  Search on inez in this thread and you will find at least one member put the kit on and he raved about.  Posted pictures too.
Yep, you right lol
There's a pretty well known turbo 14 Sierra SLT out there running low 11's on a 6/9 drop. I think you gonna be fine.
Edited by Stressin
I knew there were several 2wd turbo trucks out there, I hadn't seen any lowered 4wd trucks. This is good to know, lower it is!
I'm sitting 4.5/6.5 on a 4wd and I've got the shackles to take it down to 8" once the new wheels show up on Tuesday. Gonna wait to see how that looks before I decide if I want to remove spacers on the struts to bring it down to 5" up front. That's a lot of extra work for half an inch, and sacrifices some ride quality, but if it needs to happen then I'm all about it.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
    • subscribe to alldata.com, that will have gm's brake bleeding procedure.  and what you have to do likely varies, as if you just replaced a caliper and the MC didn't go dry, you most likely can just do a normal bleed on that corner, but if you disconnected lines at the MC or the abs unit, or let the MC run dry while doing work, you'll have to do a more extensive/complicated bleeding procedure.
