Yes and is it a rc or cc?
Mine is a rc. Truck is fighting me a bit today, getting the caltracs installed, but I'll get those pics for you as soon as I can put the weight of the truck on the axle
Are you at a 4/6? I havent seen your truck
7 hours ago, Nasty said:
Can you get me a quick picture.  I need to see the distance between your frame and axle pad in the rear. If you can hold a tape .measure in there that would be even better
Is this what you need? Sorry, it's sideways DSC_0811.thumb.JPG.80a16c7288b8f4fbb937d2f21fc41413.JPG
He posted it on the previous page :lol:
I was at 4/5, but once I get the truck back on the ground, I'll be at 4/6.f5768463c11f6a95f587946c13f213e3.jpg
That's at 5.  I'd you can do the same at 6 that would be perfect. Becsuse I might lift mine from 7to 6 in the rear
Thank you! My truck is a 4x4 so I had to do it a little different than most guys with 2wd trucks. I have 2" spindles with stock shocks and 2" lowering springs up front, and a flip kit in the rear set at 5 in that pic but next week I'll be bringing the rear to 6".
I had to do the same thing on my ‘16 CC Lovelessjl due to having 4WD... I currently sit at 4/7 based on my measurements from the ground... I used MaxTrac everything with the same setup you did...d80c762a4754682c3310a296a0454787.jpeg
Are you doing to notch it? I'm at 4/7 in my rc and I almost need a notch.  Cc sit lower than rc
No issues with my setup so I’m not gonna notch it... My flip kit is set at 5” but I had my blocks removed so I’m between 6”-7” in the rear...
Here is frame to pad, without a bump stop with the flip kit set at 6"a2bdfb7f65e882cdd4e3448c65f7462e.jpg
I’ll have mine on a lift on Thursday so I’ll measure mine as well...
1 more measurement while you're at it  center of hub to the fender. In the rear please.    I think I'm lifting mine to 6
this makes me want to got to 6'' since it's only 1/2'' difference in height.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
