1 more measurement while you're at it  center of hub to the fender. In the rear please.    I think I'm lifting mine to 6
I just saw this, I'll have that pic for you shortly
Sent from my SM-N950U using Tapatalk
That will bring my rear up 1/2"  screw it. I'm going up to 6.  Barely a difference    thank you
Nasty, I ended up trimming the axle pads to resolve the issue I was having with my notch. Gonna set it back down to 8" in the next few weeks to see what happens. I don't think removing spacers from the struts is gonna bring it down to level though...so 7 might be where it stays until next year.
what does your front measure at?
On 4/20/2018 at 5:08 PM, lovelessjl said:
Thank you! My truck is a 4x4 so I had to do it a little different than most guys with 2wd trucks. I have 2" spindles with stock shocks and 2" lowering springs up front, and a flip kit in the rear set at 5 in that pic but next week I'll be bringing the rear to 6".
What spindles? I ordered the 2" springs this morning.  What size tires are you running?
I used mcgaughys spindles #34204. I'm running 305/40/22 Nittos, they rub at full steering lock and on big bumps, but otherwise the truck drives great
Hi, new here. Very informative thread. I also have a 2017 4WD rcsb LT black. Currently leveled by 2” Belltech shackles and block removed.  Wanting to lower more to 4/7.
For the rear: Waiting for the parts to be shipped, a mcgaughys flip kit 34147 and 2210FF Shocks Belltech.
As for the front, I also placed an order for a 4” DJM CA2515-4.
If you guys can help me out here, I have been reading the latest postings and I noticed that no one uses Control Arms to lower theirs, most of you(except for one post that has, if I remembered it right 30k+ clicks with it) uses spindles , springs, structs.
Am afraid now that I may be in a wrong direction as to lowering my front. Very new to this that’s why I need advices. Tnxs
What do you mean trimmed the pad?
Do your self a favor and just do a 6 in the back.  Return the control arms for struts and spindles
Tnxs, any suggestions on part numbers? So, this was my initial problem, getting the right parts on 4WDs.
and by the way, if I may ask just so I know,  what’s the problem with control arms?
I've had issues with every djm part I've ever had. Especially the control arms.  I just removed 2sets kn the last few months from local peoples trucks.   They dont ride well, and the balljounts are crap
I have a 4wd 2016 RCSB. My truck is lowered 4/6 with spindles and springs up front, the spindles are part number 34204 from mcgaughys, and I used maxtrac 2" springs, then a flip kit in the rear. Love driving this truck around.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 686 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
