7 minutes ago, SirenRed16 said:
Middle of wheel to fender. I want to compare measurements between trucks
Mine are 17.5.  At 4" settings
I'm out of town for work today, I'll get some measurements when I get home tomorrow...
Your truck definitely looks low to me, this pic is my truck with 22" wheels and a tire diameter of just about 32". I did measure the ride height before and after, so I can verify that I am at 4" in front374d6ca3c825f126d15d0262c4e7a0db.jpg
It looks low to me also that's why I want to get some measurements so I have something to compare too.
Get measurements
Mine is at 17.5''. It looks funny because of the angle I have to hold he camera.
your's looks like 5 or 6 in the front, I wish I could get mine that low using what I used.  and I only have one ring on on one side.   The other side has no rings
Edited by qwank
Called the shop and they told me they always put 2 rings on each strut for the 4" up front.
If you get thr mcg struts i have. Tbey are good for 3"    and inez makes a camber arm for 5" drop
4 minutes ago, SirenRed16 said:
So I did a quick measure and I'm at 17.5 driver and 18 passenger
You are at 4" drop   3.5 on passenger
It appears so but still can't figure out why these trucks look different, perhaps the kit used?2da90928ee3eb03a2da6865d4a8742f7.jpg64837791e7c59eb6c9adbc87a7d19b66.jpgf28a6a92433709089bd8d5a5102dd40f.jpg
Looks the same to me.  That guy also uses djm arms
I didnt realize the McG struts did 3". Belltech is only 2" for sure.
You can thank me later
Just want to verify before I order, is this good for a 2/5 drop? 2018 Sierra rcsb 4x4. Keep in mind its Canadian pricing.
Sorry to keep asking, just hate spending money twice.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   4 Members, 1 Anonymous, 408 Guests (See full list)
