2014+ Color Match Topic
The whole tailgate handle has since been painted WDT. It's a cheap eBay cover that I purchased along with door handle covers so I wouldn't have to deal with removing any handles. Plus if I ever got tired of it, I can pull off the handles. But, I will say these covers stick STRONG
I've been looking everywhere to get the chrome tailgate handle but just the handle everywhere I look the offered the whole setup (with the bezel) I just want the handle but can't seem to find it reason being I'm gonna have a shop paint to match the whole bezel and handle then I just like to put the chrome handle on top of the painted handle
  • Replies 522
IMO, the painted cap with chrome handle doesn't look that good, but I know it's personal preference.. I think either: chrome handle and black cap, or all color matched.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Yea all colormatched is another option since I will be getting it with real paint (not plasti dip or etc.) I'm really into luxury so I'm trying to achieve that I saw a member who had red Denali did the same his avatar has the pic of painted tailgate with chrome handle but I'm trying to see if anyone knows where I can purchase just the handle everywhere I look it comes with the chrome handle and the chrome bezel. I've seen trucks with the tailgate with that combo and it's too much chrome I think the chrome handle with painted bezel is the perfect combination GM really needs to offer that in standard or at least in the Denali
Yeah they should. I have the 2015 5.2 Denali. My tailgate set up is chrome handle with black bezel. I'm thinking all color match, but then I take away that accented feature.. I'm 50 yrs old, so I'm trying to stay classy with mine.
Chrome handle with painted everything else looks great for the first hour. Then the cool wears off and it looks bad. Haha. Js. Fully colormatch it and you'll be happy [emoji106]
Lol well fully colormatch is on the table for now so we'll see
Same here.. Going to get some plastidip now.
For the forum. What's the best place to shop for plasti dip. Looking for someplace that carries an abundance of colors, as well as the pearlizer..My truck is the "WDT". I seen one member who did his fender moldings and they looked good. I just don't think using 5-6 layers of white will get me close to the WDT look.
If anyone has some experience with this please feel free to chime in. Thanks
The best place to get the largest collection of colors is on dipyourcar.com they have videos and instructions on how to mix and spray.
Sent from my SM-G925V using Tapatalk
you can use as many layers of white as you'd like. 5 or 55, but you won't get anywhere close to the WDT color unless you use a few coats of pearlizer, around 3-5 to be exact, pending on how thick of coats you put on. Ive done it, and it works great. Echavez is the member you are speaking of and he has done his grille surround, emblems, fender moldings, and bumpers
I dipped them. Along with the bumpers, grille surround (MIKE), handles, wheels, door trim, and emblems.
I still say the grille needs to go back to black
. That or your rims should go back to chrome
Dylan
Thank you Sir. I will def check out that site.
Dylan
Dylan
Echavez
That looks outstanding. I plan on doing my fender moldings, I think that's the right look. In respect to Mikes comment on your rims, if they went back to chrome, man that would look awesome, I believe they were, that's the difference I couldn't figure out. colormatch grill surround looks better than black, IMO. nice work
Thanks Mike.
Mike
You indicate that 3-5 coats of "Pearlizer would enhance that WDT look. However, In your opinion. What number of coats worked for you in respect to the white?
    xdieselmechanic
    xdieselmechanic
  • Who's Online   1 Member, 0 Anonymous, 544 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
