Tailgate Theft / Additional Locks?
diannabill
I never locked mine once, yesterday was the first time my key met my tailgate lock.. The reason? I had just installed my G4 Elite Fold a Cover and locked everything down.. By the way, that is an amazing cover.. so nice!
  • Replies 67
Is this on a '14? I tried the same thing but I can't get it to tighten down enough with the tapered hinge.
I'm still pleased with the Masterlock Tailgate Lock. I posted a photo of it earlier in this thread. It fit my '14 with no issue.
I don't lock mine.
17 years in insurance and never had one claim for a stolen tailgate (in the northeast). Plus I carry a $0 comp deductible so not an issue other than the hastle.
Supposedly there's a tailgate theft epidemic in the Houston Texas area if you're lucky enough to live there!
Read recently that there has been increasing theft rates in Austin and surrounding towns, Dallas and Houston. Keep mine locked and have the Master Lock.
I ordered mine directly from McGard. It came with an adaptor sleeve to be used when installed on 2014's. Perfect fit!
Thanks for the details on the McGard. I'll check with my local guy and see if he can get an adapter.
Sent from my cm_tenderloin using Tapatalk
I never thought of the tailgate being an item that was in hot demand. God damn I need to keep it locked from now on. I guess in new england, people view trucks differently.
Enough! I just went through and cleared out all this debate over defense of property laws. Next person who brings it up is gone for three days.
Checked with Mcgard, they said that for the '14 I need an adapter sleeve. She is sending me one free of charge. Interesting that you have to call to get one though.
Mine is always locked, insurance would cover a new one but I really don't want to deal with the hassle of getting a new one if mine were stolen.
uda9yteh.jpg This is what I got from McGard. Installed and tightened nicely.
Sent from my HTC One using Tapatalk
I just order my McGard tailgate lock today. They are offering free shipping and 10% off if you use discount code APR10
This is good until the end of April.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
