Tailgate Theft / Additional Locks?
diannabill
Was close to ordering a "Gate Keeper" but decided against it after some research. Read a few stories were the product was easily defeated and the tailgate was still taken. Guess there is enough of a gap to bend the clip out of the way using a screwdriver. Like to see a picture of one installed on a '14. Maybe the gap isn't as bad?
  • Replies 67
Eventually, I will purchase the power lock. In the meantime, this is what I did. I used a large hose clamp and a strip of inner tubing (to protect the metal and prevent the clamp from sliding). I did a dry fit and the end of the hose clamp was too long. If I were to close the tail gate, the metal from the hose clamp would have scratched the crap out of the tail gate. Therefore I had to trim the end of the hose clamp with a Dremel tool before installing it. Total cost, $2.46 with tax.
Went to install the pop and lock opened the box and low and behold there was no instructions, nor was there any retainer clip. Instruction were not a show stopper but the clip is.
Oh well, guess I'll call them Monday....
Mike
I received my Pop & Lock unit today. I had read your post earlier about the missing part so I opened it up to make sure everything was there. Crap! Same thing...the E Clip is missing. I called customer service & they transferred me to the technical support dept. saying they would help get one to me. Well, no one picked up & the message said to leave a message & they would call back. But, they didn't call. I'm beginning to wonder about this company.
Mr. mzodarg would you post & let me ( & others ) know if you got your missing part?
On the weekend I bought one of those:
CAD 19,- is much more than 2.50 for a hose clamp. I know.
But I'm hoping that it'll serve better 'cause it takes more than a screwdriver to open it.
so long
j-ten-ner
Yesterday when I initially called, same thing happened. I'm inpatient so I tried a couple more times and actually spoke to someone. They are sending me the missing part. Person I spoke to said there should have been a parts bag in the box. Told him there was no parts bag or instructions. I should have it this week.
It's a pretty standard clip.. if you don't feel like waiting you could pick up a few a Lowe's for $1. Just bring the metal cam arm for sizing (or did they also fail to send you that too?).
I keep mine locked as much to protect the tailgate from being stolen as it's to keep my tonneau cover from being stolen... it can be removed in 20 seconds with no tools.
If it didn't come connected to the motor, I didn't get it. That's what I told them so hopefully I get everything.
Mike
I use my truck bed frequently too and lock it each and every time, not sure why people have issue with that. But as ad added measure I did get this McGard unit which basically is a hose clamp in a plastic shell. But instead of a normal screw it has a keyed bit like a locking lug nut. It was probably $20 or so from Summit.
Mike
Then you're missing the clip & the cam (pic below).
Kit should also have included two sets of wires, one about 3' and the other about 8'
We'll as it turns out, I did get everything. There is a photo of something on the instructions that is somewhat in the shape of an "E" that I assumed was that clip.
Ok,thanks. I called them back and spoke to some lady. Let her know that all I got was the motor and 2 wiring harnesses. She said I should get the installation package early next week. Told her that other's would be calling as several people on a forum I belong to did not receive everything needed to install. We shall see....I'm leery!
  • 2 months later...
Is this on a '14? I tried the same thing but I can't get it to tighten down enough with the tapered hinge.
Mine is a 2011. Not sure what options exist for the new rigs.
I don't lock mine.
17 years in insurance and never had one claim for a stolen tailgate (in the northeast). Plus I carry a $0 comp deductible so not an issue other than the hastle.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
