attachicon.gifIMG_20140728_064149_387.jpgattachicon.gifIMG_20140728_064134_065.jpgattachicon.gifIMG_20140728_064142_643.jpg
Who is the manufacture of the GM/GMC Rolled tonneau cover, Not sure if this was answered before.
Pic of access Lorado installed
that's what ive used on my last 3 pkups with excellent results
I also see you put your borla sticker on the back window
mines on my toolbox
thanks for all the photos i have no idea which one to get,. I need one that doesnt allow rain to get to the bed, folds up so I cna throw my surf boards and paddle boards in the back, but can close up to keep my golf clubs free fromn the elements. i miss my "trunk" in my honda for this as I never removed my clubs lol
ok Pro's go !
Fold-a-Cover G4 Elite is a great option. Had mine almost a year and enjoy it. Very versatile and can be completely removed and reinstalled in about 5 minutes if needed.
Yes, I've had a hard cover on my last two trucks, a SnugLid SL and a Gaylords X-2000. I liked them becuase they are perfectly flat and smooth, no raised sections in the top, no weird lines or big handle, etc. like the Leers and ARE ones. They were super secure, but whenever you need to haul something taller or longer than the bed, then it's either drive with it up which even then doesn't always work depending on the length of the item, or totally remove them, which was a 2 person job with the Sunglid and a 3 person job with the Gaylords. But now with the rear tailgate design with the integrated spoiler, I'm not a fan of the way they over hang. I want something low profile that doesn't hang over the tailgate or bed sides.
I'm looking at the Bakflip Roll-X now as a more secure, roll-able, hard, but with the low profile look of a soft cover.
I've got the rollx....love it
I'm looking for a LOCKING retractable (manual) tonneau cover for my 2014 6.5' bed crew-cab Sierra, specifically the aluminum kind that roll up into a canister. I'm not looking neccessarily looking for the best of the best of the best with honors, but I do want something that slides smoothly, keeps my cargo dry, and generally isn't a piece of garbage. What are the brands I should be looking for, and am I crazy to think I can find what I'm looking for for under $1k? Thanks guys
Here are your choices:
RetraxPro, RetraxOne, Pace Edwards Jack Rabbit, Pace Edwards Full Metal Jack Rabbit, Pace Edwards Switchblade, Truck Covers USA, Truck Gear by LINE-X cover (same as Truck Covers USA but with a lifetime warranty), RollNLock, Bak Rollbak.
Best for security is RollNLock.
Worst cover is Bak Rollbak.
Easiest to operate are RetraxPro and RetraxOne.
Best waterproof - they all are pretty good except for perhaps the Rollbak.
The Pace Edwards Switchblade is a new cover, so it's an unknown as far as security and how waterproof it is.
Edited by TruckDaddy
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
