Annoyed
bigdeer1
Amen Mike, it's all about mpg, drivability suffers. And we have a hundred+ more hp than older engines and the new one's drive worse. And the old 5.7's or 6.0's got 13-14mpg, go figure. All this 'marketing' HP is only good if your racing or towing. I've never tuned a truck before, but I will on my '15.
  • Replies 87
For some reason I thought I had a 3.42 rear end... I guess not. Top right of pic it says 3.08.. Is that what this truck has or is that just an option. There stickers are kind of confusing to understand what's actually on the truck or as just an option to have
I'm sure that has something to do with the truck constantly shifting constantly. Ugh
If your going to go with a bigger tire eventually you might be changing the gears anyway. Just remember if you have a 4x4 you need to change both front and rear. .
As I mentioned earlier the inexpensive way would be to do a custom tune. I had 3.42 gears on my last truck with 4 speed and big tires. Before and after the tune was night and day. I felt after the blackbear tune it was good enough and never changed the gears.
Once it's "flashed back" how do u reactive the tune? Sorry I've never read into detail about Blackbear and how it works... & yes.. U know exactly when that sucker drops into 4 cyl mode... It's how market
Imbarssing.. Once I hear it I just slam on the gas and it eases the pain alittle..... :/
You flash the modified tune back onto the truck using an autocal (handheld unit).
I dont have the V4 issue anymore and it is amazing to drive :)
What about your gas mileage Ryan? I had a Blackbear on my last truck but it had 37's so I can't really compare any gas mileage gains from the tune. Just wondering if you get better mileage after the tune and even after disabling v4 mode?
Sent from my iPhone 5 using Tapatalk
What does a tune actually affect?
The main item is transmission shift points.
What
had 37's so I can't really compare any gains from the tune. Just
disabling v4 mode?
My truck being the L9H does not have AFM. What I was speaking of was my camaro L99 that has AFM.
What about your gas mileage Ryan? I had a Blackbear on my last truck but it had 37's so I can't really compare any gains from the tune. Just wondering if you get better mileage after the tune and even after disabling v4 mode?
Have you tried driving your truck in the tow and haul mode? It raises the transmission shift points considerably and you may find it a lot less objectionable this way. It has no effect on anything, just light penalty in fuel economy.
Read post #62
Ryan
Just tried it. Surprisingly the truck ran nice! It held a gears longer giving the truck nice power when needed. Funny because I've been averaging 8-9 mpg around town lately but once I hit two haul and noticed the difference in the truck shifting I reset my trip and avg mpg just for fun. To my surprise it drastically improved. The truck holding lower gears to accelerate and finally getting to speed the truck seemed to relax more once at a my desired speed.
good to know.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,195 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
