Gun holster / mount
I am not sure if your talking about my post but I was only making the point that one needs to pick a round based off situation. Like I said in my post alot of folks feel the hype of a cool looking round and dont know what it actually does i.e. hornady critical duty, meant to penetrate layers to hit its target. A good hollow point is the answer to most problems. I think we are on the same page though.
i shoot either ranger T/pdx-1, hornady critical duty, speer gold dots, and federal HST. They all are leo proven rounds with near nothing mass loss and superb penetration with various clothings. I like the ranger T/pdx-1s while carring in the car as they perform very well shooting through glass.
  • Replies 118
IMO Hornady Critical Duty and Critical Defense are garbage. I prefer Federal HST's or Winchester Ranger T's
I use golden sabers personally. I think the Critical series is unproven. I wont be the one to prove it either. I know in medium testing they are.
Somereason i thoigh i had the critical defense, but they are the xtp's. The golden sabers are nice in larger calibers. I had them for a 38spl and the did not expand. As you see in the pic i have them in 45 but i have yet to try them in my 1911. You cant go wrong with the pdx-1 or ranger t. If you find the white box hope on it as you cant get 50 hps that cheap anywere. I have the gold dot for my 44 mag but ibthink and thing will perform well in it. I carry the fed hst for my px4 subcompact. There are plenty of review on that round. I'll give anything a try as long as it is bonded and my gun feeds it.
niw this little bugger is a gimic. It us a 50 gr liberty defense 9mm +p. This thng is practically a thick jacket with no lead. It is super fast but the penetration suck and it turns into shrapnel. My friend brought these to the range and gave me a good laught as they talked him into them because it would make carrying his keltec a bit lighter.
Golden Sabers are good rounds as well. However, (at least in .45ACP) the Federal HST+P's have the highest velocity of anything I've found to date. In addition to that they are amazing rounds and are certified by the FBI for use in their duty weapons. The Winchester Ranger T's (formerly the Black Talons) are a close second in my book.
  • 3 months later...
Anyone found a good place to store or mount a gun in their 2014? Looking for somewhere hidden but quick to get to. Thanks!
Mine sits in the center console.
Genius. That never crossed my mind. Thanks for posting a pic.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
