That's what they are called but technically......lol
Yeah, I hear ya... Never seen an oval with squared off corners before. :)
Couldn't agree more ..... lol
Can anyone confirm that the OEM running boards taken off my 2014 will fit '07-'13 Silvys/Sierras.
Pretty sure they will NOT fit.
Im happy, found a set of Westin Sure grip boards in black for $75.00 with mounting hardware not the sexiest looking set but functional for my 5'1 wife and 5 year old, and very functional for our non existent budget!
One side was new in plastic apparently it was warrantied due to finish issues and the other has a tiny scuff. Will try and get pics after I get it on later today. Ill put a link of the set below.
http://www.autoanything.com/nerf-bars/westin-sure-grip-aluminum-running-boards-with-mount-kit
I just installed a set of N-Fab cab length on my 2015 Silverado, pretty simple install, was able to install alone, with help from my little 6yr daughter handing me the bolts and washers. Came out nice and she loves them now that she can get into and out of the truck without help.
I saw a post on here a couple months back where a member put a set on a white 07-13.
These are Westin stainless steel 4" oval step bars.
They attach to the body mounts.
Got them for a bargain price via craigslist locally.
I have the iron cross HD running boards, they dont hang lower than the frame so they wont restrict your clearance at all.
But i did have an issue with the finish of them and all the paint is coming off on both sides. But I do drive mostly gravel roads. I took them off today to get bedlinered and will post up when theyre done
That is a good idea MFLeury. I just read ever page on this thread. Now I'm considering Amps. Good lord you people make me spend money. Is there a place here to list the OEM stuff or Craig's list the best place. I'm guessing they sell for around 275. Anyone know the best place to snag Amps. No one gives mil/Leo discounts lol.
Edited by Herd Thinners
Craigslist gets you the widest -local- audience and the best chance for quick sale because you don't have to deal with shipping. And, shipping OEM boards is roughly $100 for anyone on here that might want them that's nowhere near you.
I'm torn between iron cross HD or Ici magnum. Anyone know how far each drop from the truck. Quality. Do you like them. Thanks.
Then I'll find the project by selling my OEM'
i have the ICI magnums and love them, they drop about 5-6 inches from the truck, but can be moved up and down about an inch. great quality, they don't budge and i weigh 205.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
    • The part # is 84520447, mine does not have the cooled seats but I'm willing to possibly change the cover and foam if needed.   I tried that site and a few others,  added to cart and then paid. About an hout later I received a refund stating it has been discontinued.
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
