Perfect.
Thanks
Yes, sir. All good. Give it a shot. You may need a certain angled socket wrench to get the bolts off, while the main seats are in place, but just tinker with it, they will come off.
This is a pretty long thread and I've looked through most of it but I have a 2016 with the full console. Say I just wanted to remove it to install some electronics under it. Is there a step by step for taking it out?
I am not comfortable trying this swap myself. I have contacted every Chevy dealer within 100 miles and none will do it. If any of you that have done this successfully are interested in making some extra $$, I would happy as hell to pay you to do it for me.I live in Dayton Ohio I can drive to you around 250 miles. I hate this friggen jump seat so much I am ready to buy a new truck if I cant get this done.
I am still looking for someone to do this,I came milliseconds away from buying a 16 a couple of days ago, I still have salesmen calling me all day. Again if ANYONE wants to make some $$. I will come to you with the parts and Cash and beer.
Where you located?
I'm still a little confused with getting power to the front usb's to charge. I know how and where to run the extra USB cable but how are you guys connecting the power to the USB socket. I know there is that expensive connector but whats my other option to connect to those pins??
I removed the harness from the jump seat and used it for the front of the console it has the plug you are talking about.The usb's in the jump seat use the same plug.Others have found different solutions but this worked good for me.
I have a console I am looking to sale, figured I would put it here before eBay. All parts including harness. It's heavy so shipping will probably be a lot so I am willing meet someone if close enough. The back dust cover for the 12v plug has been broke off but other than that it's like new. Came off a 2015 2500HD LTZ.
As far as price make me a offer.
How much. Will it fit in 1500?
Yes it will fit in a 1500, correct me if I am wrong but they are all the same. As for how much I would say $400 would be fair but make an offer. I checked shipping to you and it is not cheap with the size/weight, that is the only downside..
How heavy is it? And can you send more pic epically the break you wrote of
The console itself is just over 32lbs. My zip is 91730.
I added pictures of the damaged area and of the console.
I removed it from the truck with about 10,000 miles and sadly that little cover broke while it was being stored.
Very interested. Could we come to terms on shipping and price as a package thing. It says ~$140 to ship to where I am at in Indiana.
Can you help me out as well man. I cant locate some of this stuff. Much appreciated
Hi, Simonmcnasty, I can get that all done for you. I'll message you.
    Carlos Monteiro
    Carlos Monteiro
  • Who's Online   5 Members, 0 Anonymous, 1,079 Guests (See full list)
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
