Not really what "i've" done today but rather the lady behind me who decided to use my truck as a bump stop...099e5fd39cdfb00432c4565bf289ee7d.jpg
That's why I keep a hitch on my truck [emoji4] extends 13" off the bumper! That way it's the bump stop and my truck isn't.
Yeah I do but mine is sitting nicely under my rear seat right now. Figures huh?
Well that's not a good place for it! Should be covering your rear end
Yup live and learn I guess
Nothing too exciting, but did get an AMP Research BedXtender HD Max installed this afternoon. Glad I also ordered the spacer kit since it took a pair on both sides in order to clear the flip-tab releases for my Roll-X tonneau rails. I'll take pics later -- but love having some additional usable space for groceries/ smaller parcels.
Not sure what project will come next -- mulling OEM MY14 tow mirrors, but also have my eye on adding factory navi...
New projectors and 55 watt HID lights this weekend. Now I need some high beams that match the color of the 6000K kit and also need to decide on the fog lights. If the fog housings don't cost to much I'll try HID lights to see if they melt or not. If not I might pick some lights that just match in color.
That stitching looks pretty tight. Is that the OEM leather that was re-sticthed or new replacement seat covers?
Put new LED tail lights on my truck, and ordered a new 2015 Silverado for work. Pick it up Friday or Sat.
Royalty Core grille installed, painted the grille border white, and lower valance painted black. New tow hooks are here, and paint to match mirror caps are here. Just need to finish up. post-135722-0-76335500-1417134296_thumb.jpg
Edited by iicoolbreeze
I added some new tires:
BFG All Terrain KO2's
285/65-18 on stock rims
I got 5 and another stock rim, going to rotate in the spare.
So far they're real nice:
Nice looking wheel? Any rubbing issues and are you running a 2" or 2.5" level?
I have same rims and need to upgrade tires. Looking at Cooper S/T Maxx 285x65-18 (32.8x11.8) and was wondering if they'll rub.
Thanks
Jeff
Thanks
Jeff
Jeff,
With stock 5.5" backspace wheels, you shouldn't have any problems. I went to a 305/60-18 ST Maxx without rubbing. It was very close. No room either way for a different offset.
http://www.gm-trucks.com/forums/topic/161086-cooper-st-maxx-30560-18-121x326-18-no-levellift/?hl=cooper
If you really want to find out how much room you have and what offsets you can use, follow this
The technique I used to figure out what size would fit on my half ton was:
- start the truck and crank the steering wheel to a stop in one direction and loop the seatbelt thru the steering wheel to hold it at the stop while leaving the engine running.
- check the clearances front and back of both tires with a small scale (ruler). The tight areas will be the sway bar and fender liner (front and rear). Taking some pictures will also help for reference later.
- go to the tire manufacturers website and look up the specific tires you have. Write down the dimensions for section and tread width, as well as diameter.
- go to the manufacturers website for the tire of your desire. Look up the specifications and write them down.
- Do the math.. Dont forget that any change in wheel offset or width will affect all of your clearances.
-allow for some clearance. Especially on the things that are not going to give, such as suspension components and frame . The fender liners can move and/or be tied back to give more clearances, Especially the bottom edges. Also, the suspension moves up and down, but the tire does move a slight amount in and out during the travel. Don't be greedy.
- pay attention to where the critical areas are and remember: at the corner of the tire, the tread width and diameter change will both change that corner clearance.
- also figure out how wide you wheels are (or will be) and stick within the tire manufacture's recommendation for wheel width of the particular tire you select.
Have fun. I was able to put 305/60-18 ST Maxx tires on my stock rims of my half-ton without any lift and had no rubbing during driving. Others did have rubbing with similar size tires. But the rubbing was on the fender liners which seem to be floppy and not consistent in shape on the bottom edges.
