Is that the stock replacement lights? I ordered the 3000 lumen high powered ones that they said would ship maybe mid month. Hoping you did to and they shipped early.
b10d13077f9c23f47d3a2013acf544c4.jpgb81edb457652b4f69d7081405e0c0c2c.jpgcabc72b00b24e06f0360f5657f5dcd5a.jpg
I installed my ANZO U-Bar Style headlights. I LOVE THEM! Gives the truck a great look
What kind of lift and size tire you got under that thing?
Sent while in 'Murica...
I just have a 2.5" rough country lift. Came with a leveling kit as well as additional spacers for the top of the struts and 2" blocks for the rear. The tires are 265/70-17 Fierce Attitude M/T's on Moto Metal 951 rims with a -12 offset.
I love the stance!
I love the stance!
Nice. I'm looking at the Top Gun customz level kit, no rear blocks with stock wheels and tires for right now until I need new tires. Then I either want the sierra all terrain wheels with bigger tires or just keep these stock wheels and put bigger tires on them. I have the same wheel on my 02 except in black. Same offset as well
I did take off the lower air dam yesterday and it makes a big difference
I really like the look without the air dam. I'm gonna do that today.
I've also been pondering the idea of a bull bar on the front with an LED light bar. Something subtle but still keeps the cleanliness of the truck
Took me 10 minutes with a 10mm ratchet wrench (flex head) and a flat head to pop out the 4 retaining push pins (2 per side). There are a bunch of 10mm bolts under there. I believe I'd counted around 15 or so. I think if you could mount the led bar in the bumper somehow that would be awesome
Go with it! I did that to my truck and it looks way different with and without the bullbar. One of my neighbors thought it was a different truck lol
DC0EB30D-0220-4141-AF7C-37F46ECB3F19_zps
That's exactly what I was envisioning. What bull bar did you go with? Size of LED bar?
Plastidipped the area between the side windows so it looks cleaner. Also dipped the Z71 and SIERRA emblems on the sides only and the chrome door molding. So now all that is black. Also removed the antenna completely. Haven't noticed any reception issues and I took the truck for a 2 hour drive tonight. Can't post pics right now for some reason but wish I could to show yall! Looks so much better.
EDIT: got a photobucket so now I can post this way
434E86EB-883C-4E6F-B247-0E82C5AD4BBA_zps
You beat me to it! I have a can of black Plastidip ready to go, but temperatures have been a little too low for spraying. Good to know the end result will look great, though! :-)
20" light bar and a Westin bull bar! I painted the bottom plate on the bar black
Just noticed you have LED cubes for your fogs. You like them?
What did you get?
Thanks!
Also, what's the measurement where you have your light bar? Was hoping to possibly fit a 30". With brackets it's about 33"....think there is enough room?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
