While those bulbs will technically work in the backup blubs spot they aren't really bright enough for you to be able to see anything with. You might not even be able to tell they are on over the light your brake lights put out.
Agreed. I went back to the regular bulbs cause they put off more light than the leds I had in there. A good led bulb costs too much for what it's worth
EDIT: This was on my 02
Sent while in 'Murica...
Edited by rdnckhntr94
Never mind. I bought the 10 pairs. I can use them for backup bulbs and license plate bulbs. And give a couple pairs to my father in law.
Yea just like Coaster said, those things are not going to help at all in the reverse lights. Those are going hurt your vision more than anything.
Added the Z71 logo on my bed today. I like the sticker and the badging up front too.
Looks good! I have thought about it for over a year. I have even seen them on other color trucks, mostly the black/gray stickers. I really like the way yours looks with the red "Z". I put the All Terrain grille in mine and added the Z71 grille badge. Thanks for posting.
Thanks! Yeah I love your grill! I planned on doing the same thing just gotta get the money for it haha. I saw that full lock has the stickers on his slt and thought man that's cool.
I've had my 14 denali for about 4 months and I've done a few things; window tint including windshield and sunroof, HID 6000k kit, LED fog lights to match color of headlights, billet 9" antenna, 24" KMC wheels, 3" drop on rear, gatorhyde spray in bed liner, rolling bed cover, more to come soon! Loving the truck so far
Anyone looked into or have rollpan installed? 3rd brake light changed out? Removed front emblem? I tried to look thru previous post but so many didn't see it anywhere
Edited by FORGIVEN06
Tinted windows with nano film
Changed stock 4x4 z71 emblem.
Bedrug with bullring tie downs.
Cooper st maxx 275-65-20
2" level
1.5" zone body lift
Plastidipped bow ties.
post-130620-141857222532_thumb.jpgpost-130620-14185722341_thumb.jpgpost-130620-141857225458_thumb.jpg
factory paint matched egr fender flares.
  • Like 4
Has anyone removed rear emblems on GMC yet?
Yes, I did when I bought the truck last November. It really easy, took me about 15 min. You need a heat gun, fishing line, and a rubber wheel on a drill.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
