Yes, I did when I bought the truck last November. It really easy, took me about 15 min. You need a heat gun, fishing line, and a rubber wheel on a drill.
Did you remove all the emblems and was there not any holes after removal?
Really like those footwell LED's that you installed. I plan on installing some as well except I will have them wired to the dome light, can't be that hard right?
I have just one question though- is the white that those put off equivalent to the soft white of the dome lights? Thanks and nice truck!
Sent while in 'Murica...
Did you ever find out if you could hard wire those LEDs in to dome switch? I like them but wouldn't like mine to be on all the time and I do wonder if the color is the same.. Do you know?
Yeah it can't be that hard. I get my lights in on Wednesday and may tackle it that evening. There is a thread on here talking about wiring in lights on a gmt900 and I'm pretty sure it's the same. If you give me some time I'll figure out the wire that it needs to be tapped to
Yes I have time, I'm still debating on handling the task. Let me know and post some pics if possible! Thanks!!
also recently installed Plasmaglow Fire & Ice Light bar. Hard wired it by swapping out the 4 way plug for a 5 way and then modded both left and right tailight wire harness so bar can be easily replaced if it goes bad.
Do you know if you can install those so that they only come on when u brake or back up? I don't think I want them on with running lights
I performed warranty on my old 2008 truck that my brother bought from me 6 months ago. We replaced the 140,000 mile upper control arms, which had worn ball joints, with the UCAs from my 2014 which had only 10,000 miles on them when I replaced them with the Cognito UCAs. About 1 1/2 hrs total, with a tire rotation in there to boot.
I also got my gun drawers back from the bed of the old 08 and put them in the 2014.
Edited by spurshot
Experimented with an "extra" bumper I came across, plastidipped the plastics to get a feel for the look..and well now I'm stuck trying to make it happen for real because I love the look!
Looks clean. Luckily the plastics already match the color of my truck lol
I like that look too. I just don't see myself doing though. First time I put a muddy boot on the step it'd trash it up.
BTW, I like that you went with chrome/polished wheels with the white. I'm not and never will be a black wheel guy.
Edited by spurshot
Could you just not wire in the the running light wire?
That's kind of what I was thinking but I'm not for sure, thought maybe someone had tried it or knows if possible
The durability is what puts me on the fence about it. I've read tons of "cen cal" threads and have seen dirty/abuse to clean pics of painted plastics and most swear that with proper prep you won't have any issues. Just a bit risky though...especially when you already have a perfectly good powdercoated white bumper to begin with Edited by baggedlvintegra
I have already wired our other '14 so I will test when i put the one on my daughters '05 colorado. (week or so)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
