It's sideways, I know. I'm terrible with computers, I have no idea why it keeps doing this. Anyway list of current mods;
2014 Sierra All Terrain 6.2 in Iridium metallic
Rough Country 2.5" level
Zone Offroad 1.5" body lift
Custom exhaust Aero Turbine 3030's with black MBRP tips
20x9 Fuel Krank's
285/55/20 Open Country AT2 Extreme
Smoked Tails and 3rd brake light
Beamers 6000k HID's
Rigid Fog light kit
Color matched wheel well mouldings
color matched mud flaps
AFE momentum intake
2 12" JL Audio Subs
N-Fab cab length ankle breakers
Shaved all badges and emblems
20% tint all around
...I'm running out of ideas
20x9 Fuel Krank's
Beamers 6000k HID's
Rigid Fog light kit
AFE momentum intake
2 12" JL Audio Subs
20% tint all around
Put a blower on that 6.2 lol
Sent while in 'Murica...
If I had an extra 20 g's I could just wipe my a$$ with, I would. Unfortunately that isn't the case lol
Edited by retodd709
20x9 Fuel Krank's
Beamers 6000k HID's
Rigid Fog light kit
AFE momentum intake
2 12" JL Audio Subs
20% tint all around
Running out of ideas? You must not have been around here for long! You'll get some more. A lot more. Don't worry!
Nice I like them much better black.
Sent from the future via a wifi time portal.
Did u do then yourself or have them done? How does it hold up
Plasti Dipped my stock A/T wheels black.
Did u do it yourself or have it done? How does it hold up
I'm not Gatori but I feel like I could answer your question as well, I did mine in August and have only had an issue once and that's because I missed a spot so it started peeling. I haven't had any issues other than that. Mine have held up very well. Just make sure you've got a good 4-5 coats so it's easy to remove if needed.
Just thought I'd give some input on dipped rims!
I did black and I put on about 6 or 7 coats. It seems to hold up. I've had mud on them and rocks hit em in the few days that i've had it. Only time will tell.
Its been long over due of what ive done so far: got my windows and windshield tinted, added a gibson exhaust, added floor lights, added lights to the center console that come one at night, swapped out headlights for projector lights and HID, plastidipped bowties and side emblems, rough country 2.5" lift, swapped stock tires for 275/77R18 exo grapplers, plastidipped rims (need to be redone after getting my tires)
Did u wire in the LEDs ur self? If so how did u get them to come on only at night and do u have an override switch or would it be possible the way u done it? Ur light setup up is unique and I like it!!
Yes i wired them myself, I can take some pictures later of the wires i tapped into. It is possible for you to wire a switch in to turn them off. As of right now the red lights dim with the interior dimmer switch, the white lights are only on when the doors open.
Could the white light be wired to dome switch too? So if I turn on dome lights then foot light will come on? Thanks for your help
Yes. Just tap into the dome light switch wire. I'm going to be doing mine soon
Sent while in 'Murica...[/quote
Which is what wire is what I was asking? If anyone knew?
I'm not sure exactly which wire but there is a youtube video on it. I believe it is gray but not 100% sure
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
