I don't really haul anything though. I have an employee that works at Summit racing who is quitting here shortly, so I'm leaning towards the Corsa while I can, Lol!
Good choice then lol
Installed some camo Z71 stickers. And finally was able to clay and seal the truck a month later than I planned.
Tire rotation, replaced license plate lights with Sylvania Zevo 6000K LED's, packaging says super bright, will have to wait for night fall to decide on that. They are at least not yellow anymore. I also ordered a Winjet fog light kit on EBay. Not exactly what I want in the end but comes with wiring harness, switch, new face plate and OEM like light assemblies. Figured it's worth the money spent for a starting point.
Removed GMC emblem on tailgate the other day and installed white reverse and cargo lights today! Thanks Tallspawn!
Sent from my Nexus 6P using Tapatalk
Edited by cjz28
Oh yea, also replaced factory antenna with this stubby. No idea if it even works. Just listen to Spotify mostly.
Washed it, changed the 710 and filter and added my last sticker16ea88e1e7dee3bccc04f72c6f7915c5.jpg8b94108ec631748201b20666ce2e9c41.jpg
What reverse bulbs are those?
If u are asking me, they are JDM ASTAR.. I can share the link with u when I get home or they are on page 366 under "post pics of your 2014+" thread...
Sorry can't do much on my phone.
They are great by the way. Very bright at night and the white color looks 10x better than the stock yellow lights. Very happy I ordered these.
Nice. I ordered some of the Philips 921 leds so i hope they're nice and bright like those.
I went with the Philips over the AStar ones because I read about them burning out a lot. Hopefully you have some better luck.
Edited by cbrsilv15
Get the deal while you can.
Not really today but going to be a fun weekend. Motofab 2" level tomorrow and Morimoto HIDs from the retrofit source go in on Sunday!
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
