Did a little grille swaping today. (Before)45f20252541e630ec4f3cd61966b7835.jpg
Picked up this grille for $100 locally. Much better. Debating on painting the head light trim black. 0439baf33b8fbaee6fb176ec880ed710.jpg
Sent from my VS985 4G using Tapatalk
looks good - maybe add led light bar ?????
Much appreciated, where are you thinking? Like behind the grille?
behind the grill
Dropping my truck off this Sunday to get the new hood painted some time next week. Should cost about $250 for them to paint and do any final adjustments.
Paint match the headlight trim it will look much better!
Nice!! Aftermarket cowl hood? I think your right. I might paint them this week or look for some good reviews on the headlight trim covers and see if those are worth it or not.
They're finally in stock... I ordered Nitto Ridge Grapplers today 33x12.50x20.
They should be here in the next week.
Just take the trim off and have a shop paint them. Shouldn't be expensive at all.
Already painted black? That's a damn good deal!!
Yeah already black and with the black painted bowtie. I was just scrolling across Craigslist here in Tampa fl and there it was lol. Couldn't pass it up. Now I could probably sell my stock one if need be or If i have room in my attic lol
Edited by tyler.r.jacobs
HAS any one seen a midnight edition = with a bull bar w/ led light bar (lund) ??? If you got photo's ,Please share. Thanks
Got rims installed 6c1e05a2bb874ac2c5f440c5a8169405.jpg0ac9966dd946aeb629900e73bed960a7.jpg75cc889189329c1c3937622fe1a18b68.jpg6558defd44af8a032f3a48f44ed0b1ca.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
looks good - maybe black bowtie / letters ???
Want to paint bumpers and add black bowties and shave the rest. Going to paint the chrome bezels on my stock headlight this weekend and put them back in.
Edited by wildhunter
Got windows tinted finally!!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
