Where did you buy your Corsa DB muffler? I can't find any online. Every website wants to sale me a 4 inch inlet/outlet version for a diesel. Thanks!
Lucked out and found one on eBay from a parted out truck. From what I've seen they're impossible to come across unless you get the entire cat back system. Best of luck sir!
Removed the lower front air dam on my '16 Z71. This is just the piece that sweeps down in front of the wheels at the front corners. Gained me about 3 inches of ground clearance in the corners and about an inch in the center. Eventually, the plan is to removed the other black piece and chrome "skid plate" completely and replace it with an aftermarket skid plate and bar of some sort.
Before: 6tNlcNxl.jpg
After: 296bCfpl.jpg?1
Thanks for the heads up. The hunt is on. I wonder if the db system for an 07-13 would fit? I thought I remembered reading on here somewhere where someone put the exhaust from their old sierra on a new one, and it fit with zero modifications.
i think the pictures need to be a little darker.....
looks good. close up of the light bar / how is it mounted . Thanks
LOL it's not my truck I dunno how it's mounted.
looks good. how did you mount light bar
I would do them summit white, ties into the grille nicer
Swapped my hostages back on.
B590015B-DC28-4F88-9403-CC704CD537AD_zps
looks good. new grill inserts or whole grill ????
No problem. I don't see why not, it's just piping. From what I understand the DB series of exhaust systems was developed for the 07-13 body. The new "Sport" exhaust is for 14+.
He got high country grille. His headlights look like crap. My non cleared would look better. Should ship them to me asap to swap. :fingersx:
Need everyone's opinion, even if they are negative lol. So I'm looking at either aftermarket replicas or aftermarket with a little more offset than stock. Im stuck between 3 wheels. As you'll see, I don't like anything too busy, just something simple and clean. Here are my choices
Sierra All Terrain replicas; I would stick with a 20" wheel and just use my current tires. This is one of two cheaper options
http://www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_id=64452
Dick Cepek DC-2; can't find a pic of them on a k2 truck, but if I went with these I would most likely go to an 18" wheel and have to purchase new tires, etc etc. This would be my most costly option but with a -13mm I think it would set the truck apart, besides the fact that a good bit of jeeps have them from what I see lol
http://www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_id=64453
And last but not least would be Dick Cepek Gunmetal 7's. If I went with these I think they actually look good in my factory 20" and I could reuse my current tires. These have a good offset at +13mm, so it wouldn't stick the tire out past the fender, but close to flush I believe. I have really grown towards them and I can get them to my door for under $900, a tad more than the Sierra reps, by maybe $80 or so
http://www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_id=64454
http://www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_id=64455
http://www.gm-trucks.com/forums/index.php?app=core&module=attach&section=attach&attach_id=64456
In my mind, comparing cost and looks, I think the Gunmetal 7's take the cake. On a black truck I think they look good. I also have always loved the Sierra All Terrain wheels, and those I wouldn't have to worry about any rubbing (don't think the Gunmetal 7 wheels would rub, but the DC-2 wheels with a 33" tire and a -13mm offset may rub on a 2" level). Anyways, y'all shoot your opinions my way!!
Yeah, oh well. Best I could do since I was at work and using my phone. I work nights. Really appreciate the sarcasm though.
It's mounted with a license plate bracket mount. Since I'm in Ohio, we have to have front license plates, which gives a good place to mount a small one. The bracket I got was on amazon, link here. I plan on doing something more cosmetically appealing with the wiring as soon as I get a free weekend.
Yeah sounds like you should really "lighten up" big guy LOL
Clever. :P
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
