Paint is done. Fitment turned out well.08a07b13a0d07bed8b16a59aa5d4da05.jpge5b76e35005045eb5d755b5bd7c1b183.jpg3e71b762fb4e67ce8972488dc936dd02.jpged4ddb0a4af1085e189904d3e5024c9d.jpg6d5afd79c8577cefd28c6a282eb8fa09.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
Looks great! I also see your antenna faded as well. I contacted the Amazon seller a few months back and sent me another one for free.
Sent from my SM-G930V using Tapatalk
Pretty happy with the way it turned out. Need to get rid of thw chrome on it though. Cant believr they sent another antenna. I am going to have to do that. Thx for the tip
Yep, sent the guy a picture of it and received a new one two days later. How did the underside of the hood turn out. Could you post a couple pictures?
Looks badass! Overall how difficult was the installation process? Did you have any fitment issues? I've been toying with the idea of getting one but I'm not sure how it'd look on my pickup.
Undersidecca757ae5c0777dbeba8182de8f320b3.jpg8c22a51db869990aefecfa4f698c286f.jpgb820830ff9351f891d95657606b99c18.jpgca8c4d181a9642482baa68585bbb33f4.jpg2fed55de0425f4809a97b429ed94befa.jpg
FYI that is tonneau cover seal.
How about 3m clear bra on hood / bumper cap = Rock Chips ?????? so does your truck have any miles on it .
4 bolt installation. Simple. Sits just a hair high on passenger side hinge area barely noticeable
Al is my daily driver. He goes everywhere. Closing in on 36k36699b048267a5858e4e119cd1757a71.jpg
Thanks man, it looks great!
Dropped it off at dealer. My vacuum pump is dead and that seatbelt recall had to be done, plus fixing a clunk that came from the front suspension.
I put around 8,000 miles on the truck over the summer, so I guess stuff like this was expected.
Edited by Hisdem
After only 8k miles stuff like that is NOT expected. Hopefully its still under warranty.
I wish! My truck is a '14 with 47k on the clock. This is the first expensive repair I'll have to pay for (and hopefully the last).
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
