On 9/30/2017 at 3:01 PM, War-eagle173 said:
New wheels and tires 295/70/17
What wheels and tires are these? They look good! Have you leveled it?
20 minutes ago, jimmyboy8301 said:
It would look fantastic I bet!!
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
My wife is finally OK and understanding of some of my mods but I have a feeling she would choke me if I tubbed this thing and narrowed the rear end to get some wheels with a dish! BTW, I just hit you up on Instagram so I could see more pics!
Anyone know why my pictures upload upside down?  I'm using safari... not sure if there is an app for the forum or not.
A lot of people like myself use the Tapatalk app.
I can't upload pictures from my phone on tapatalk says the picture file is too big
Sent from my E6653 using Tapatalk
17" method mesh with a 0 offset. Ridge grapplers and a 2.25 level
Mounted the winter tires on the 18's I had. If it stops raining I'll put them on the truck. Also mounted the AVS AeroShield before the rain started.
Hahaha it would be cool though, and [emoji1417]
4.5" Zone
22x10 AF Grips
New climate controlfe813307af5f30ea7f9d05393f1c679f.jpg0407a6d8cd8559da6d57e5f6cee9b592.jpg
I’m sure the first question will be - “Is this Plug and Play?” Lol
If you don't care about the dual climate control, than yes. If you do you have to run a new wire.
4.5" Zone
22x10 AF Grips
I agree but I've already pushed my luck! (she didn't realize I turned the truck into a 2 seater when I did the console swap so I took it out to stay out of the doghouse!) BTW, you look like my cousin Milton from Baltimore (or he looks like you! :))
So I assume you have the dual climate control working? If it's not too bad I may have to look into this. I wasn't too concerned about the dual climate control when I bought the new truck but my wife has mentioned that she misses not having it since the last truck had it.
I agree but I've already pushed my luck! (she didn't realize I turned the truck into a 2 seater when I did the console swap so I took it out to stay out of the doghouse!) BTW, you look like my cousin Milton from Baltimore (or he looks like you! [emoji4])
Hahahahaha
4.5" Zone
22x10 AF Grips
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
