Duck season is over so got the opportunity to do a pre-detail clean up. Clay bar, polish, etc to follow in a few weeks
On ‎1‎/‎23‎/‎2019 at 8:38 PM, SS502 said:
Awesome upgrade! The older Snowflake rims are still my favorite but that truck looks sweet ?
AMEN on the Snowflakes. Best looking Factory wheel out there if you ask me!
Yes Sir!
Added an Agency 6 billet shackle block and a Razer Auto billet shackle. To plug up my receiver hole.
  • Like 4
Made a bike rack for my bed out of PVC, after measuring it out to fit exactly to my bed so it wouldn’t slide around. Spent less than $35 and it breaks down to 2 parts for super easy storage. Pretty strong but I just needed it to haul my bikes a couple miles, nothing crazy. Helps keep the bikes in place while I tie them with the cargo loops.
Also replaced the cargo lights by the third brake light with LED.
I like that. Can you get a shot of it from farther away?
Here you go. They make them in different colors too. You can mix and match. I wanted a little splash of red. e61a9c1fcbf98078d28111e94f875a46.jpg7fe4c99f6fcc23c975aae350caea2170.jpg
  • Like 4
Perfect, thanks.
I am going to get the blue shackle block, but with this Royal billet shackle
Image result for royal red shackle hook
Perfect, thanks.
Holy crap that’s a beefy shackle. That’ll look great.
I have a 2014 GMC Sierra All Terrain did the 7-9 inch Mcgaughys lift kit I had it set at 8 inches high with the rear traction bars and upper control arms all by Mcgaughys, wheels are 20x10 -12 offset Fuel Mavericks and tires are 35/12.50/r20 Toyo open country R/T also have the amp research power steps, backflip revolver bed cover, recon tail lights and recon 3rd light brake, pro comp 40 inch light bar custom OEM headlights with the switch back led boards and demon lights, recon bullet antenna, Morimoto fog lamps, Borla s-type exhaust, k&n air intake black gmc logos z71 grille emblem, window visors and last the weather tech oem gmc floor mats. eb0f0364c6d9d788d3ba1f76ef2e897a.jpgf3f3ae55d9f9b6d578e3e4206879b621.jpgd25cd68afcb2843e5a2b770ad1586a37.jpga203fbe75eda8cb049b7404622b2ba34.jpg9377d810991bea5e7cc21aad253c7fe4.jpg6c45955b338ca24194fc331104c32397.jpgd73f3cad98a68b56fd4ba23e69f3c36b.jpgc06def5b37fe1b6d8b2485dce9d9a561.jpg64b1f7aa473fcdcf5508a099cc2be0bf.jpgfa804371d59ec577d4e6ad30933d96ea.jpg
  • Like 5
Looks great! How long have you had the lift and your reviews on it and any possibilities in the future for coilovers?
Sent from above
Sent from above
Yea future I would like to do coil over, had it for a week or so and love it, my brother in law had the same set up and it was great on his truck he had it for years
You did really good. I think that’s the #1 thing everyone should consider first is a high end lift, after all it’s the foundation of which you’ll be building all future additions.
Sent from above
Added led lighting to truck bed, and did the diode mod so I can activate the lights with the key remote.
Ok, my order has been placed. Do you have a locking hitch pin? Seems like that whole rig would be tempting to someone just to take off with the thing.
Shakey
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,263 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
