Duck season is over so got the opportunity to do a pre-detail clean up. Clay bar, polish, etc to follow in a few weeks
On ‎1‎/‎23‎/‎2019 at 8:38 PM, SS502 said:
Awesome upgrade! The older Snowflake rims are still my favorite but that truck looks sweet ?
AMEN on the Snowflakes. Best looking Factory wheel out there if you ask me!
Yes Sir!
Added an Agency 6 billet shackle block and a Razer Auto billet shackle. To plug up my receiver hole.
  • Like 4
Made a bike rack for my bed out of PVC, after measuring it out to fit exactly to my bed so it wouldn’t slide around. Spent less than $35 and it breaks down to 2 parts for super easy storage. Pretty strong but I just needed it to haul my bikes a couple miles, nothing crazy. Helps keep the bikes in place while I tie them with the cargo loops.
Also replaced the cargo lights by the third brake light with LED.
I like that. Can you get a shot of it from farther away?
Here you go. They make them in different colors too. You can mix and match. I wanted a little splash of red. e61a9c1fcbf98078d28111e94f875a46.jpg7fe4c99f6fcc23c975aae350caea2170.jpg
  • Like 4
Perfect, thanks.
I am going to get the blue shackle block, but with this Royal billet shackle
Image result for royal red shackle hook
Perfect, thanks.
Holy crap that’s a beefy shackle. That’ll look great.
I have a 2014 GMC Sierra All Terrain did the 7-9 inch Mcgaughys lift kit I had it set at 8 inches high with the rear traction bars and upper control arms all by Mcgaughys, wheels are 20x10 -12 offset Fuel Mavericks and tires are 35/12.50/r20 Toyo open country R/T also have the amp research power steps, backflip revolver bed cover, recon tail lights and recon 3rd light brake, pro comp 40 inch light bar custom OEM headlights with the switch back led boards and demon lights, recon bullet antenna, Morimoto fog lamps, Borla s-type exhaust, k&n air intake black gmc logos z71 grille emblem, window visors and last the weather tech oem gmc floor mats. eb0f0364c6d9d788d3ba1f76ef2e897a.jpgf3f3ae55d9f9b6d578e3e4206879b621.jpgd25cd68afcb2843e5a2b770ad1586a37.jpga203fbe75eda8cb049b7404622b2ba34.jpg9377d810991bea5e7cc21aad253c7fe4.jpg6c45955b338ca24194fc331104c32397.jpgd73f3cad98a68b56fd4ba23e69f3c36b.jpgc06def5b37fe1b6d8b2485dce9d9a561.jpg64b1f7aa473fcdcf5508a099cc2be0bf.jpgfa804371d59ec577d4e6ad30933d96ea.jpg
  • Like 5
Looks great! How long have you had the lift and your reviews on it and any possibilities in the future for coilovers?
Sent from above
Sent from above
Yea future I would like to do coil over, had it for a week or so and love it, my brother in law had the same set up and it was great on his truck he had it for years
You did really good. I think that’s the #1 thing everyone should consider first is a high end lift, after all it’s the foundation of which you’ll be building all future additions.
Sent from above
Added led lighting to truck bed, and did the diode mod so I can activate the lights with the key remote.
  • Like 3
Ok, my order has been placed. Do you have a locking hitch pin? Seems like that whole rig would be tempting to someone just to take off with the thing.
Shakey
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
