Weird my driveline is completely different, what cab/box is your truck?
Crew cab 6’6 box 5.3 6L80 2wd
ok, mine is the same but 4wd, my driveline is a big fat sucker no center bearing
You got that 5” aluminum DS?
So I haven’t picked up the truck yet waiting on them to finish lifting the rear, got late so they finishing today 9” McGaughy Lift definitely need bigger tires and wheels!!! 8B4592E5-79C7-4C34-8047-9A4DD26B116F.thumb.jpeg.18e22a0c48c04f2d48a479ebc52db2ec.jpeg
  • Like 4
ya I think so it's a big fatty I was under it the other day looking to see if it was the oem one or not, my truck is lowered 4/6 and I get some vibrations but hard to tell what the cause is I don't know if it is the tires, wheels, driveline, or something else.
Console, aux switches and made a relay panel thanks to Phil for the console harness
1 hour ago, doubeleive said:
it's a big fatty
So many directions to go with this one, but seeing how it is a PG13 site.....
Mine got that Chevy shake since day one. But not THAT BAD. Until I dropped the back 3.5”. Then it’s really bad. Adjusted the driveline angles and it’s like 99% gone.
Static or a notch in the back?
2” drop shackle with the block removed. I got about 3.4” out of it. No notch.
I do have VAS traction bar, hellwig’s sway bar and air lift or rideRite air bags with custom brackets for towing. Gonna grind the overload leaf off soon.
On my 04 RCSB, I started with a 4/6, had to put the factory shackle back in, new shims and it was very smooth, just a harsh bottom out once in a while.
It shook so bad at the start, they ended up replacing the transmission case because all of the seals were leaking. Took it the first week on a 100 plus mile drive each way, was the craziest thing I have ever encountered in a car.
Oh damn. At least they replaced everything for you! I got extended warranty but I don’t wanna take my truck in for anything!!!! I’ve done a good amount of things to it now that they might just not touch any of it.
On that body style, there is a pressed in seal at the end of the transmission where the output shaft exits, and has a little boot with a weep hole on it, they all start dripping at one time.
The shake broke the seal and my was putting lakes of fluid on the floor and on the bottom of the truck.
The dealer installed the drop, so it was warranted by GM.
Ahhhhh i see. That’s cool tho.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
