I just has a 6inch BDS lift kit installed. Dealer sold me lift with upgraded Fox 2.0 shocks for just about 1900 and install was about 700. All depends where you go and if they will work with you.
That's awesome, my local dealer quoted a similar price over the phone. I'm actually ordering my 6" BDS kit with coilovers and glide rite leaf springs tomorrow.
Your getting ripped off paying $700 for installation of your BDS. I payed $300 to get my 4" BDS installed on my 2007.5 and it took them a day and a half to complete.
Edited by jakefinn
Considering the instructions claim 7-8 hours, most of all shops are gonna charge 7-8 hours labor plus environmental and such. Hell, it only took me 4 hours to do my 02 when I installed my lift, that's just all extra profit for them
I live in Upstate NY and the only part of the lift kit I can't do myself is the welding. In NY to pass inspection the welding has to be done by a certified welder. Also I have 37s so there was some additional time required for slight trimming and pinning the wheel well back. Shops up here charge about $66 a hour for labor and the dealerships are higher. When I was in GA had a shop quote me $500 for install but that was 2 years ago.
Edited by Ryans14ThungstunZ71
37's on a 6" lift? What offset wheel are you using and how wide is it? Only lift I've seen that will take a 37" tire was a CST 8" lift
In my opinion the $700 is a pretty fair price. The front end alone will take a few hours, another couple for dropping the gas tank and installing the leaf springs, then another hour or so to move the tpms to the new wheels and mount/balance, an alignment and a 15 mile test drive before delivery.
You can fit them on a 6" but you'll need to trim the bumper some. I talked to BDS a while ago and they said on a 20x8.5 w/ 5.5" backspace you can fit a 37x12.5 without trimming. But only if you are planning to drive ONLY on nice pavement. If you plan to hit any kind of roads with bumps in it then you'll need to trim the bumper. The black truck on their site advertising the 6" has 37s on 20s on it.
Offset is 0 the wheel is 17x9 Dick Cepek Gun Metal 7
I'll just stick to 35's considering I may want to actually use a 4wd truck off road lol. I think I'm gonna wait until they make rear gears available for our trucks before I install the lift and bigger tires. Too sluggish without regearing
I've already tested my truck with the 37s off road so far no issues just had the shop check it out after the first 500 miles after lift ended up being more about 800 miles. Shop said no rubbing issues and no problems that they could see. They guarantee there work so if it rubs and messes up the tire they will replace it. I already some how got a scratch on one of my new wheels. The shop said they would order a replacement and take care of everything. Edited by Ryans14ThungstunZ71
I can't believe how much the off road shop next to my work just quoted me to install the 6" BDS lift. Are you guys ready for it, $1500-1700. JUST FOR INSTALL! My jaw hit the floor when they told me those numbers. Guess I'll be driving the 60 miles to my actual "local" BDS dealer for installation. By the way on my lift I will be running a 20x10 with 4.5" BS/ -24 offset with a 35x13.5r20 tire. I think I'll have some trimming to do lol.
I was gonna run the same backspace/ offset/ wheel width and tire combo. Let me know of any rubbing issues
Actually I'll be running a 12.5 tire, but same rim size/ wheel width/ offset
Edited by rdnckhntr94
I'll keep you update once I get everything installed. Follow my build thread too!
Edited by crafferty
Rough country UCA's with moog ball joints
There was another member that wasn't able to get the RC UCAs to fit correctly and had to purchase a different brand. Did you do the install yourself? Maybe RC updated their design.
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
