did a little color matching and blacked the grill out, also finished up my headlights! now the front end ties together nicely!
  • Like 5
you cant post something like those badass headlight mods without more pictures!!!!!!! :ughdance:
Looking good!!!
Damn, looks good! Really like the headlights
thanks guys, just went out and took some night pics, phone camera doesnt do it justice..there both also switchbacks
  • Like 3
Ok those are stock lights. What all did you put in them? Where did you get these items? Where are you pulling power for the u bars? Are they on all the time like a daytime driving light? This is the first ddl that doesnt look tacky on a sle.
Edited by Crooks
dipped my bumpers.
Looks good. Im thinking of dipping my bumpers and headlights, does the white plastidip match the stock white pretty well?
Yea it does. You can tell the dip is more white but not a big difference.
I added the flexible led switchback tubes, led tower bulbs and also put led concepts halo kit in them, then just did some painting.
Your links dont work
Sounds very reasonable. So this converted it from single exhaust to dual? Not exactly right. Did it get rid of the flapper valve some people don't seem to like? (What that heck is the flapper for anyway? Keep the squirrels out -LOL)) Hope you get better performance HP and mileage too maybe.
The flapper is for when it drops to V4 it helps to not have the bogged down sound.
Do your oem drl's still come on then or did this bypass that feature?
yes, the OEM DRL still come on.
I'm interested in one of those pieces but slightly different. My truck isn't 4x4 and no trailer brake. I want a trim piece that just has the hole for the lights and that little wheel and the rest is solid. You think you can make something like that? I want to put switches in that space for lights etc.
it would be better if the switches going in at the same time.
Well I don't even know what type of switches I would want haha. I was thinking I would just cut whatever hole I need for the switches as long as I have a solid piece to cut through.
d85f813943e9ef65d854ecb4783a0a92.jpgsomething like this, but factory look, and I would just cut out whatever template my switches are.
Edited by NitroDatsik
Where would you put the trailer brake controller and the Transfer case Knob?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
