Finally got 'round to installing my MY14 tow mirrors (i.e. manual extending, heated, w/ turn signals) on my '14 Sierra SLE. Driver's side is completely done, including door harness swap. Too thrilled to see the turn signals work on first try. Ran out of daylight or else I'd have finished the passenger side...pity getting the door panel weatherstripping back on is a bit of a PITA...
What did you use? Looks awesome!
got them done at a body shop haha. I was going to do them myself but figured I'd bite the bullet and have them done professionally so they would hold up better overtime
You have to cut a hole in the exhaust pipes and just weld it in. Not hard if you have the tools and know how I suppose. But I don't have the tools, nor have I ever welded, so I can't give you a true "this is how hard it is" opinion. I had the muffler shop I got it at install it. Took them about an hour to an hour and 15 mins from the time i handed them the keys to the time I got w call saying it was ready.
Install and cut out ran me $325 ($355.xx after tax) and that's with me running the wires. I told them I'd rather do that part myself so that I can have it exactly how I want it (also saved me $75 + tax)
I'll get you the model and brand in the AM. The shop stopped selling cut outs for a while cause the last brand they sold kept having issues but they found this one and have been selling them for around 2-2.5 years now and no one has come in with a single issue yet
Here is the brand you have for anyone wondering
http://www.badlanzhpe.com/collections/kits
Finally took off the dealer decal. Each letter was separate, what a PITA!
03795abc8d3da24639f3d0124b1dc03d.jpg changed the cabin air filter
how do you do this? my air vents have a weird smell to them, thinking this would help a lot!!
I got some Michelin LTX AT2 tires put on...275/60R20's and pulled my factory step bars.
did a little color matching and blacked the grill out, also finished up my headlights! now the front end ties together nicely!
This truck looks incredible
very nice
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
