Finally, tow mirrors on! Big improvement from the undersized mirrors it was built with. My hands still hurt from fiddling with the harnesses...
Smoked the tails!
B48E4D42-4D31-482C-BEB8-40530D379142_zps
What up Mike, what body shop did you use and how much did they cost to get them smoked?
Deep South Whipz, they are on Veterans just past the airport and it was $120. They had them done in about 4 hours from the time I dropped them off
. Would have been cheaper at your local flea market. Got my brothers tundra done at one of our flea markets for $120, head, tail and 3rd lights. Is been 2 years and still look good. One thing tho, I don't recommend doing Headlights because it will lower the light output. if you do it, do like 1 to 2 coats. Edited by NitroDatsik
Nice, and the visibility is still good for the previously red portions? I had my last truck lights smoked, but was always nervous I might get rear ended and then they would blame it on the smoked lights
I went ahead and plasti dipped my Silverado emblems and bowties today. Loving how easy it is to use this plasti dip!!
yes visibility is still pretty good. If you are worried about getting rear ended then just get them smoked a bit lighter than mine. I told the guy to go to the unofficial legal limit which means that you can still see some of the red lens
I am somewhat worried about the same, but if it comes to it, they will try to blame it on smoked tails if they are lightly smoked or dark smoked
Edited by Mike1220
Put the K&N back in today the ACDELCO still looked fine. Ac has about 15xxx miles on it... just going to use the k&n and clean it every 50xxx miles. About to vlean the engine bay e53a76fef0bedd1d2cace94e592e8e81.jpg
Installed my nose camera today, I will post some pictures when I am not on my phone lol. Worked out quite good actually!
Build thread or how-to?^^^^
Yeah, coming coming, sometime this week ok?? Been working a lot. 12 hours of work yesterday and 2 hours of driving on top of that. And I spent 2.5 hours installing this! :')
Sneak peek!!
I definitely need this with my lifted silverado. When I park in parking spaces it feels like I am about to drive over them then get out and theres four feet of room between me and the other car lol
  • Like 5
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
