Made an appt to drop my truck off on Monday for the following issues:
*heated seat cushions don't work
*trans periodically slips out of 2nd into 3rd
* "Service Driver Assist System" error message
* slight vibe felt in the seats and steering wheel (can especially see the pass. seat shaking) I know what yall are thinking, OH NO!!! [emoji33]
* paint spot that has been there since the day I got it, so small didn't notice it till first hand wash
* and to top it off, I need my annual state inspection done (free bc I bought the truck at that dealer, one of their incentives)
Really like the winjets. How do you like those winjet headlights? How's the light output and are they adjustable?
I have to take mine in for the driver sensor too. They say it's the wires being worn in two by the seat cushion on the left side.
If they fix it I don't care what it is lol. People look at me funny when I tell them it has to go in for warranty work at 22k. Makes me feel like I bought a sub-par truck. Should have just stuck with my instinct and bought an 06-07 2500HD Duramax LBZ
Took my truck in saturday for a free oil change and asked about a noise when turning slow and dim headlights. They checked it and told me it needed the steering rack replaced, my truck only has 14,300 KMS! But on a good note they replaced the bulbs and flashed the bcm.
Sent from my SAMSUNG-SGH-I997R using Tapatalk 2
Swapped out my chrome mirror caps for Summit White ones. I thought the chrome caps were overkill. Planning on leaving the chrome trim and handles though.
I really need to order my Amp steps. I hate the factory ones. I think removing them will also make the truck look much better.
Looks much better!!!!
Finally got the windows tinted. Kept the rear doors and rear window factory. Had them put 20% on the front 2 doors to match the rear and had them put a windshield brow along the top at 5%.
I'd like to see a pic of the brow from the inside headed into the sun if able.... Don't crash lol
I have to wait a couple days for the glue to set before I can put the windows down or put the ventshades back on. I was going to wait until I can put the ventshades backs on before I take updated pics so I'll take a pic of the brow from the inside and outside.
The output is ok since it's halogen. The projector is Bi- Hi and Lo built-in.
The adjust screws is easy to access to.
Not quite into the sun but gives you an idea
Sent from my iPhone 6+
I think I saw that thing in Close Encounters.
Where did you see it? lol
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
