Added putco nite-lux led headlights hi/low/fog
Lund stainless led bull bar
Custom switches in the dash
Elite engineering catch can and clean air oil separator
Engine cover off a Cadillac 6.2 motor(waiting on a Chevy emblem)
Putco led reverse lights and license plate lights
When you say "catch can and clean air oil separator" that is all the same unit right? I ordered the EE catch can and want to make sure I don't need anything else.
The clean air oil separator replace the oils cap on the truck. It's a separate piece then the catch can. Check out elite engineering. You don't really need it it is optional
From what I am reading the clean side separator isn't really needed with a wet sump system like the trucks have. Definitely needed on the Corvettes with the dry sump.
Have you noticed any residue in the clean side separator? $100 doesn't bother me if it will help, but if it's negligible then I won't bother.
I would say it's optional. I figured it can't hurt. I've only had it on for a day and haven't driven the truck much so I haven't seen any residue. I did notice some in the lines I had going into the cold air intake. For the 100 bucks I figured I'd give it a try
For the guys running the vled lights what's your honest opinion on them are they brighter and better then stock or are they just for looks..
Sent from my SM-G900W8 using Tapatalk
I run them on my low beams and they are a billion times better than stock.
However, the improvement on my truck was massive because I didn't yet have the BCM voltage fix done when I changed them out, so stock was essentially no lighting at all.
Have you ran them in the fog lights that's mainly the ones I want to order but I don't want to shell out 60 bucks for lights that just "look nice" id like to see an actual improvement as well... And bcm fixed what's that? Was it a recall?
Oh, I haven't had them in my fog lights, so I can't help there.
The BCM fix wasn't a recall, just a bulletin. In the '14 models you can go to the dealer and ask them to increase voltage to your headlights, as well as replace the bulbs, making them brighter than originally. The '15s already have this done from the factory.
Good to know thank you i figured as much because my 15 has awesome headlights! I just don't want the halogens in the fogs anymore... If anyone has them shed some light please or is there a better bulb to go with then vled... ?
Installed Volant "Closed Box Air Intake System" today
Edited by chuckl1218
I have 25w LMZ fog lights. They actually produce beautiful beam pattern from OEM housing. They also do make a difference even with my 55w DDM HIDs.
I am going to order some 45w LMZ knockoffs for a fraction of the cost even after shipping. I might get two sets and have them in my current fog lights. And my 25w somewhat fitted into my reverse.
Do you have a link to those 45 Watt bad boys I may give them a try and see how i like them if there that much cheaper...
I dont have a link, only a skype contact... Haha i wont be home for another 10 days anyway, I also wont order them until i am home so I can check if I can fit the 25w bulbs in there.
amy.sun82 is her contact. I am in Canada, but her quote for a pair of 45w is only 69.99 USD and another $30 for shipping to Canada. I imagine it would be same or cheaper in US.
I saw the pictures, they look identical to the LMZ, not sure what they call it though
Edited by morrislee
I'm also a fellow Canadian where you from im in Manitoba and we'll then maybe I'll bite the bullet and pull the trigger on the vled did you have issue fitting yours or anything with the clips iv read about and how was fitting them... Also what year I your truck a 14 or a 15
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
