Yesterday decided to debadge the Z71 4x4 decals from the sides of the truck, then today decided to paint it and add it to the grille
1AD9F689-95AC-4CB0-A760-3CBC9868C43D_zps
Also decided to pull the GMC logo off the rear, painted the chrome semi-gloss black and letters to match the truck, now about put back on. Also painted the second Z71 4x4 to match the rear emblem and putting it on the rear as well
Edit: for anyone who wants to try and do the Z71 similarly where you'll paint the X a different color on the 4x4, be warned that its a huge PITA to tape it off just right and even more difficult to get it to look good. I took about 7 tries and several hours of trying before I just settled for "close enough"
Edited by Mike1220
  • Like 3
i agree....front end looking like a damn christmas tree lol
Forgot to post it up the other night
F333A945-CA8F-450C-8F12-7FA11B42E110_zps
Here's a pic of the tailgate done
Window tint, front and back. Worlds of difference with the heat blocking in our Texas summer. My arm isn't burning when it's up on the door and the truck has remained cooler after leaving it in a parking lot for a period of time.
If you do the windshield it does even better. Left my truck out in the sun all day and got in and it was like walking into an AC'd house
How did you do this?
Not mine, but I've done similar with foam and an electric fish filet knife. Other option is a hot wire gun.
Did you tint the entire windshield or just the top 6 or 8 inches? Where I am, illegal to tint below 6 or 8 inches. And I think the "eyebrow" looks dumb.
Eventually maybe. They make a tint that's not really darker but does provide the heat and UV reduction if I am not mistaken.
Got my 2013 running boards put on yesterday! Woo looks nice! b4d9edf216af247a71e0309a3c380ae4.jpg6bde5a4c9bc16e14ef704086049730ed.jpg72ef12ef25f49bfaf54a7ff646a9a64f.jpg3aaba50aa7976e102fb073625af59929.jpg
Sent from my SM-G900W8 using Tapatalk
It's illegal here too. But I've had it for around 8-9 months now without issue. I've talked to cops from Texas and LA and they've said as long as you aren't doing anything to attract attention to yourself then a cop shouldn't pull you over for it.
They do, I know Llumar makes one but it's expensive. I got some cheap film on mine. I think it's Suntech carbon. $110 installed vs the $250 for the Llumar Air 80 installed.
I also need to pull mine off every 2 years for a brake tag/inspection sticker so that's why I cheaped out.
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
