Drove 700 miles to enjoy a week in Georgia's countryside. Averaged 21 mpg cruising at 75mph the whole way. I'm pleased!
Enjoy my home state : )
Lol, more power, but no it's just a filter, [emoji20]
Well, what oil did you use wuth the filter? :D i cant tell, you are hiding the labels in your picture lol. How is your oil draining thing so clean!?
How does it feel to have K&N filter in there??
I prefer Mobil 1 filters, but I've wondered about the aluminum K&N reusable oil filter. Haven't really seen anybody that uses one, even a few years ago when I first saw it available for my 98. I don't think they have one for the K2 trucks yet, but I'm still wondering about how it is.
I used the stock oil, AC Delco synthetic blend, oil oil is draining throw a 3/8 hose off of a oil valve that I installed, the oil still looked good but kinda watery, probably because it was over 100*
I don't know why I used the K&N filter, just kinda figured I have a K&N air filter and cab filter so why not a oil filter too, all 3 are K&N, I think it's my OCD kickin in
The K&N oil filter is nice, I have it in my ford escape now. I should do that now ti my truck niw that the 4 free oil change is done.
I would not even think about the reusable oil filter, they are less than like $20 a piece, why risk?
Removed the hideous pin stripping along the truck and removed the Z71 decal. May ad the sierra style z71 emblem or remove the silverado badging and add the custom sport type.
CD733801-68D1-4580-AB23-6D348DAF9C7A_zps
I replaced the bed decals with the Custom Sport/Midnight Edition Z71 door emblems. From a distance it looks factory until the sun hits it or look at it a little close.
Edited by SouthernSilveradoGuy85
Bit of a loss for me today. Finally decided on "camo green" as my accent color... I did 8 coats, determined that each new coat would give me a darker or deeper, true camo green. It didn't. It looked booger green from every angle. Spent half my day applying coats all for nothing ... Think I'm just going to do red. (And yes, this is PlastiDip)
PS. Didn't bother peeling it correctly cause at that point I had pretty much decided I wasn't keeping it
Edited by OSMEAC
Put my huskys in today. X-acts for the front and full weatherbeaters in the back. The fit isn't perfect but I'm guessing that after they've had a chance to heat up in the truck and stretch after being folded in a box they'll fit a little nicer. Is that the case others have been seeing?
Edited by tootall87
May I ask what made you choose the x-act for the front? Im picking up weather beaters for the back for sure but Ive seen quite a few people get the x-act for the front instead
After reading a lot from this forum it was stated that the x-acts have a softer rubber feel vs the harder slicker plastic of the weatherbeaters. While I'm sure the front weatherbeaters are just fine I don't want my feet to be slipping around.
I've got the weatherbeater in the front and rear. No slippage. Fit perfectly. My dog doesn't even slip in the back when hes standing up looking out the windows. Very pleased with them.
I'm disappointed in the fit of the x-acts on the front passenger side. It won't stay in place and really just doesn't fit well. Thinking about going back to weathertech, but I hear they don't fit well either.
A little cheesy but added 3M carbon fiber vinyl wrap to the bowties. Matching the tungsten metallic paint is difficult which is why I went with this.
  • Like 4
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
